I created a path object that is basically some lightening.. Whwn I try and resize it using the transform tool I get the bounding box around the lightening
but when I drag the baox to resize it either clips the object if I am trying to shrik it or crates duplicates of the object when I enlarge it... I can successfully resize any path object that I copy out of the easypalette jus not the one I created... Any ideas ???
Problem Resizing Path Object
heinz-oz
keenart
sting
I still have the file that I was having problems with... I tried going to properties and changing the width and height there as well and had the same problems with the object getting clipped or duplicated if I increased the size...
I recreated the path object and sized it to the proper size and rotated it to the position I needed it in without problem....
I now suspect that the problem I had with the first file was caused by multiple transforms that had been done to it including conversion to an image and back to a path object several times...
I was using Photoimpact 10 to do this....
