"Simple Caption" script - change font?
Briansdad
motherboard: ROG STRIX Z690-A GAMING WIFI D4
processor: 12th Gen Intel Core i7-12700K 36
ram: 32GB
Video Card: NVIDIA GeForce RTX 3070 Ti
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: BenQ SW271
Corel programs: VideoStudio 2023
Post by Briansdad »
PSPx7, simple caption script: I want to change the font and maybe italic/bold/normal. My attempts at editing script resulted in errors. Tried changing [FontName] to the name of desired font but failed. Can it be done?
Bill
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: "Simple Caption" script - change font?
Post by LeviFiction »
Yes, you just have to know how to format it.
The Scripting language is Python. Python is very easy, and very readable but, Python is also very picky about how you write things. I recommend a Python tutorial so you know how to write basic Python code. CodeAcademy is a free option.
The font name is written in what's known as a string. Strings must be surrounded by quotes. These can be single or double quotes but the opening quote must match the ending quote. And the entire line must end with a comma. For example.
Code: Select all
'Font': 'Times New Roman',
The reason that the "SimpleCaption" script doesn't show this is because it's using a variable that's defined in another script altogether.
To add bold to the list you need to add the 'Bold' parameter. Capitalization is important here.
Also spacing is important. When indenting lines of code you must use the exact same amount and type of spacing. For example, 'Font' 'Italics' and 'Stroke' are all indented 12 spaces. You cannot use tabs, you must indent the exact same number of spaces.
Code: Select all
            'Italic': App.Constants.Boolean.true,
            'Bold': App.Constants.Boolean.true,
Make sure you add a comma after App.Constants.Boolean.true
If you want the text to be "normal" instead of bold or italic. Just set the 'Italic' and 'Bold' parameters to App.Constants.Boolean.false
Briansdad
ram: 32GB
Post by Briansdad »
Thanks. This looks like exactly what I wanted. If I have further issues I will try CodeAcademy first.
Thanks again.
Bill
