For work I have to work with Corel VideoStudio in the past 10 years, and each upgrade needs me to change the language setting from another language to English because the workstation is set in a different language.
I did that by modifying u32comm.ini in the Program File folder (for example, C:\Program Files\Corel\Corel VideoStudio Ultimate X7). You can use notepad to edit this ini file.
There is a list of country code in this file. Look up your original country code XXXX, then change all the
;LocaleID=XXXX
into
;LocaleID=0409
Then that will change the menu back to English.
Solution to changing language in VideoStudio Pro X7
