I show the performance tab because it lists the HD Games template I created. I think I am putting two and two together now. The HD Games template I setup on the performance tab is solely for the proxy file. Hence, why it is captioned "Video proxy options" above the template details. See, this is why I am posting here; to learn! Thanks!lata wrote:Again the “Performance tab has nothing to do with your video output, it is purely there to create Proxy files used to smooth timeline playback, providing details of the performance tab is only confusing the issue.
I didn't think having the proxy files in the same location would cause issues. I checked the Smart Proxy Manager and the list is empty. Do you recommend placing the proxy files just in a different folder or to move it off of the D drive completely to the C drive?lata wrote:If D:\Editing\ is used to store your MPEG4 video files then change that location for proxy files.
Do not store proxy files along with your video files. Doing so will only confuse you further.
First clean / purge your proxy folder.
Go to Settings Smart Proxy – Smart Proxy Manager- Select all – Delete selected proxy files. Change the Proxy folders location to another folder.
I checked the show messages box, but I don't get the message to match the project settings if I have my HD Games Project Properties template pre-selected. So, my template must be compatible. If I change my project properties template to my DVD Games template (non-HD basically) then I am prompted with the change box. I attached a screenshot. I had to scroll the both columns down in the box to get the bottom lines but the top line for both read MPEG-4 files.lata wrote:Editing Workflow
Go to Settings Preferences – tick Show Messages when inserting First Video.
Start a new project, add one of your Mpeg4 video files.
You should get a message to match the properties choose yes.
Go to Settings Project Properties – copy and paste the details in the right hand panel to this forum.
Are you able to do that?
