Creating a Video File
56belair
- motherboard: ASUSTeK COMPUTER INC. P8H77-M Rev X.0x 100MHZ
- processor: 3.40 gigahertz Intel Core i7-3770
- ram: 32GB
- Video Card: NVIDIA GeForce 8400GS
- sound_card: AudioBox 1818VSL Audio
- Hard_Drive_Capacity: 2x 1000 GB
- Monitor/Display Make & Model: 2x LG 24EN33
After I edit my individual AVCHD video files from my camcorder into a .VSP file I need to create a video file in Corel x5. I select Create Video File-> AVCHD -> 1930x1080p. When the file is converted and I play it back, it looks grainy. I want my final video file to look a bit sharper like from the source of my camera. Please advise
Paul
Parker, CO
Paul
Parker, CO
Paul Jarrett
Parker, Colorado
Corel Video Studio Pro x5
Parker, Colorado
Re: Creating a Video File
Hi Paul
You do not give much detail regarding your video files except AVCHD..
From Share – Create Video File --- Is the option Same as First Clip available, assuming your first video clip is indeed one of your Avchd.
If available copy and paste the properties details/text to this post.
Also
Create your own template.
Go Settings – Make Movie Templates Manager – Choose Add – browse for one of your files.
Give it a name
From Share – Create Video File at the bottom of the list will be your template
The above should render using the original videos properties.
Oh --- press F6 – edit tab – set Resample quality to Best
Also
Give it a name
56belair
- ram: 32GB
Same as First Clip available is an option.
Attached are the properties of the file I'm creating that doesn't look as good as the source video. The snapshot is on the left
Also attached are the properties from the source video which I'm making my edit from. The snapshot is on the right
Paul
Paul
Paul Jarrett
Parker, Colorado
Parker, Colorado
canuck
By going from 1440x1080 to 1920x1080 you are adding interpolated data into each frame which will not really give you a better picture but in fact seems to be degrading the video. If you want the video to be as good as the source you should choose the original video properties.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
canuck, he is going the other way around from 1920x1080 17Mb to 1440x1080 6Mb.canuck wrote:By going from 1440x1080 to 1920x1080 you are adding interpolated data into each frame which will not really give you a better picture but in fact seems to be degrading the video. If you want the video to be as good as the source you should choose the original video properties.
Panasonic X900m, VXF1
Hi Paul
What version of Video Studio are you using....
There seems to be some confusion with these properties.
Just to double check…Please use Video Studio, start a new project --- insert a clip to the timeline, right click and choose properties, post an image of that window.
Now do Share – Same as First Video Clip—the render details show in the properties box, use the mouse to copy and paste those to your post.
They should be the same as the image above.
canuck
Right but in his first post he said " I select Create Video File-> AVCHD -> 1930x1080p. but his properties info is the reverseasik1 wrote:canuck, he is going the other way around from 1920x1080 17Mb to 1440x1080 6Mb.canuck wrote:By going from 1440x1080 to 1920x1080 you are adding interpolated data into each frame which will not really give you a better picture but in fact seems to be degrading the video. If you want the video to be as good as the source you should choose the original video properties.
In that case he is dropping data
Hi canuck
I think we need Paul to confirm his workflow?
if Paul did use the "same as first clip" then it is quite strange to render to 1440 x 108056belair wrote:Same as First Clip available is an option.
56belair
- ram: 32GB
did create video file -> AVCHD -> 1920x1080.
After reading your comments I did create video file - > same as project settings.
Paul
Paul
Paul Jarrett
Parker, Colorado
Parker, Colorado
56belair
- ram: 32GB
Create Video File snapshot
Paul Jarrett
Parker, Colorado
Parker, Colorado
canuck
I thought you wanted to create a 1920x480 AVCHD video? Your last snapshot shows the properties for a mpg (DVD quality). Is that what you created? If yes then of course it may look grainy compared to HD video.
Paul
You should render your video using the properties shown on the right hand image, Share Same as first Video Clip should do that
56belair
- ram: 32GB
Thanks for the info guys.
Paul Jarrett
Parker, Colorado
Parker, Colorado
