VSX6 --> VSX8 upgrade ...install problem?
- OBB
- motherboard: Dell XPS Studio 8900
- processor: 6th Gen i7-6700
- ram: 32Gb
- Video Card: EVGA GeForce GTX 680 4Gb
- sound_card: RME RayDat
- Hard_Drive_Capacity: 6Tb
- Monitor/Display Make & Model: Multiple
- Corel programs: Painter15/Paintshop-pro/Sketch
So I did the upgrade from VS X6 ultimate to X8 ultimate yesterday, mostly for the extra chroma-key options... But after installing it? right away something is missing... Most of the transitions & FX, including the most basic ones like "fade to black" & FX like "ghost motion" suddenly are all missing in X8...
Per Corel's tech to upgrade he said to simply uninstall X6 & then install X8. And because of it being the upgrade version that it would ask me for both serials & keys. So I did what he said, I uninstalled X6 and then installed X8 but on install it only asked for the new X8 key and did not ask for the X6 key.
So I suppose my question is How do you do the upgrade correctly... Do I now uninstall X8, re-install X6 and then install X8 on top of it?
Re: VSX6 --> VSX8 upgrade ...install problem?
Corel Video Studio X8 Ultimate comes with three installation files.
VideoStudioUltimateX8_64bit_1Main.exe
This installs the main program, limited library content
VideoStudioX8_2Contents.exe
This installs the additional content to complete your installation.
VideoStudioUltimateX8_64bit_3Bonus.exe
This Installs the Ultimate packages ProDad etc.
In addition you may have purchased
VideoStudioX8_Blu-ray.exe
Have you installed all files?
- OBB
- ram: 32Gb
Yes I've downloaded & installed them all twice now and both times I get the same exact result...
Am I suppose to leave X6 in place when you do the X8 upgrade?
Very strange, I would have thought that if the X6 serial number was required that the Main program file would not install, and that must have installed ok.
Did you have the trial version installed.
Reset the program by re-naming the folder 18.0 to “18.0 Copy”
Go to Start and Paste %appdata% to the search panel, that should find the Roaming folder
Browse to find :-
C:\Users\Trevor\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\18.0
Rename that folder
I assume you have installed the 64bit version
As for X6 yes you could have left that installed, most of us have several versions installed
But as the main program has installed there should be no problems
Browse to find :-
Rename that folder
- OBB
- ram: 32Gb
You would think...lata wrote:Hi
No, I have 2 licensed machines on X6... Trying to know why half the content comes up missing with the upgrade version before doing the other machine as well...lata wrote:Did you have the trial version installed.
Just did this, now when I try to open X8 it loads to the point where Vitascene tries to load but then won't load any further past 64% and If you throw CTRL/ALT/DEL at it, X8 doesn't even show up in the process to end it... only way to end process is restart the machine...lata wrote:Reset the program by re-naming the folder 18.0 to “18.0 Copy”
Browse to find :-
Rename that folder
I guess I'll try installing it all a third time...
- OBB
- ram: 32Gb
Ok, so installed it now a third time & watched it very well all the way through...
I can install the main program X8, no problems as fdar as I can tell... On completion If I open X8 it has all of the standard transitions & FX are there, including "fade to black"...
So next I installed the "Bonus pack"... used the "Install all" option, after install I went and opened X8 again and looked at the transitions & FX menus... All The FX are there but the transitions menu is cut by nearly 1/2 in quantity.. If I look at my laptop still running X6, I count 128 transitions, in X8 I notice after installing the bonus pack it drops to 54 transitions in the menu, including "fade to black' now missing...
From there I installed the "Content' package... and this fills up the content menus as it should but now you are stuck with the 54 transitions left & now the other 1/2 of the FX are missing again as well... I would think the bonus package & the content package should be adding menu options, not subtracting them...
This is so frustrating...
- OBB
- ram: 32Gb
...and it looks like it makes no matter how many times I download them.. going on install #5 now... It flops every time when it installs the bonus (prodad, blue etc..) it wipes out all the transitions, something is screwy with the upgrade & this isn't right...
This is not how to have fun on a Friday...
- RobertOZ
- Hard_Drive_Capacity: 7 TB
I don't know if it will make any difference but the Contents Pack should be installed BEFORE the Bonus PackOBB wrote:Ok, so installed it now a third time & watched it very well all the way through...
- OBB
- ram: 32Gb
Have done both ways half a dozen times today... The main X8 program loads fine, the contenet loads fine... It's something in the Bonus pack, I'm down to installing each plugin separately and so far the problem seems to pop up when you install the new Boris Adorage plugin... Got the main Boris plug-in in but as soon as I added Adorage, I lost 60% of the standard transitions...RobertOZ wrote:I don't know if it will make any difference but the Contents Pack should be installed BEFORE the Bonus Pack
- OBB
- ram: 32Gb
...And so now on install/upgrade attempt #7 and still going...
From the upgrade package... You can:
Install the 64 bit X8 package, without a hitch...
Install the 32/64 bit Content package, without a hitch...
BUT---
From the upgrade download version of "Bonus Content" here is what I know what now happens...
...I've resorted to installing plug-ins separately and here's what I know, first hand...
When installing the bonus content..
All goes fine, with these 2 exceptions below:
1) You can install almost all "Bonus Content" ...BUT... The moment after you install the Boris Adorage pack, after install, if you open X8 and you will find you just lost more than 60% of all transitions, with the majority of the ones being gone are the most simple, such as "FADE TO BLACK" and 50+ others in one fell swoop... doesn't matter how you install it, automatic or individually... So in a nutshell, the moment the Adorage package is introduced... While I can see a few new Adorage transitions added to the menu, you still loose more than half of your most basic standard transitions... My guess is there a bug in the download upgrade package somewhere...
2) I also found out that when go to install Vitascene? The install abruptly asks for another Serial # (it will not take the X8 serial, it wants more digits) and from there you can't progress the installation of Vitascene... and that bonus also no longer works... Again, my guess is there a bug in the download upgrade package somewhere...
I sure hope they fix this... I love using Corel products, been using them for decades now, but... I'm tech savvy enough to know that an upgrade installation is not supposed to be this difficult at all!
BUT---
- RobertOZ
Ok, Can you try installing X8, then install the contents pack, then check to confirm that all your transitions are there, if so go to C:\Users\username\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\18.0 and rename old, relaunch X8 and let the 18.0 folder rebuild, close X8 and then install the Bonus Pack, launch X8, if the transitions are missing, again go to C:\Users\Username\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\18.0, now rename the new 18.0 folder Old and remove the old from the existing 18.0 folder, so you are reinstating the original 18.0 folder, then relaunch X8, do the transitions now appear, I have had the same issue with transitions disappearing and doing that solved the problem for me.OBB wrote:1) You can install almost all "Bonus Content" ...BUT... The moment after you install the Boris Adorage pack, after install, if you open X8 and you will find you just lost more than 60% of all transitions, with the majority of the ones being gone are the most simple, such as "FADE TO BLACK" and 50+ others in one fell swoop... doesn't matter how you install it, automatic or individually... So in a nutshell, the moment the Adorage package is introduced... While I can see a few new Adorage transitions added to the menu, you still loose more than half of your most basic standard transitions... My guess is there a bug in the download upgrade package somewhere...
I think you should re-download the Bonus Pack, it should not ask for a serial number for Vitascene, so you could have a corrupt download
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
How did you tried to install Vitascene? You must run it from the splash screen not from it's folder.
Panasonic X900m, VXF1
I ran some tests installing the program in different orders, it did not seem to matter whether Bonus or Content was installed first.
Installing the Content last should re-install the library, so any personal library pages would be removed.
When we run the installer setup files are extracted to the Corel , these being used to install the program.
For subsequent installs it may be best to delete these, I don’t know if the originals are used or overwritten. Maybe save to a different location, then install.
I have just extracted to a new folder on my desktop.
The setup files has folders for each plug-in_X64
The Adorage folder is 164 Mb (172,265,951 bytes) --- 5,201 Files in 149 Folders
Maybe you can compare that with the sizes you see.
As Asik says install from the splash screen,
Installing from the folder will probably cause problems with serial numbers.
- OBB
- ram: 32Gb
Yes I've renamed the 18.0 folder three times now... all it does here is make X8 hang-up & freeze while trying load vitascene, and then you have to shut the machine off and when you open X8 again after restart it's back to square 1... transitions mostly gone & then 75% of the effects in the FX menu spit back a Corel VideoStudio error message stating "insufficient memory 15036:0:0"... and if I look at task manager it shows nothing being used on the memory end... And this machine has 8Gb Ram available so I'm scratching my head on that now too... And I also get an odd message when I click on the motion guide icon it says "you're graphic card does not support this feature"...which is even more strange as It worked just fine in X6...
About the only thing I can even remotely think of now is maybe there was an old files from the X6 installation conflicting with this install?
Thanks Lata for the viatascene file size to check against, mine shows the exact same file size you have... And yes when I save the setup files I save it to a separate folder not in the program tree...
Later today someone from Corel is supposed to help me try to install this via remote connection and hopefully they will be able to sort this out... I'm sure hoping that I'm not going to be recovering this entire machine this weekend... Fingers crossed.
Thanks for the feedback,, good luck
