My DSLR is Nikon D3300.
The NEF looks very normally in ViewNX2.
But when it is opened in ASP(Newest Version). it looks so green.(Especially in dark environment.)
For the detail, plz look the screenshot.
plz help me.
If there is no solution,i am afraid i have to use LightRoom5.
BUG NEF looks so green in ASP2
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: BUG NEF looks so green in ASP2
Could you please post a comparison with the Nikon rendering?
And, what happens if you use click WB on the light gray part of the chair?
cheers
afx
cheers
afx
Dear.
Thanks for quick replying.
I am in home now.so i have not windows, hence i can not open it in NX2. But another tool called Darkable in linux. it can see this NEF perfect.At least the WB is right.
Yes,your method can deal with the green problem. but it is not correct. it became a little red.
It means that the newest version ASP2 can not recognize the correct WB for D3300 NEF.(RAW 12bits)
this screenshot is opened in Darkable.
U can see the TRASH backlight is write.
In ASP2 it is green.
Any Soultion?
afx
- System_Drive: N/A
Not here..
Contact support.
cheers
afx
Contact support.
cheers
afx
