Can you tell me if it is possible to change the duration of many images insert in a diaporama in a single step.For example I have a diaporama with 50 images and I want to change the duration of images 3 to 10 from 8secondes to 10 secondes?
Thanks for your answer.
Diaporama
Re: Diaporama
There is a setting in the Preference (F6), Edit tab to modify the default duration of inserted image clip.jcmmarin wrote:Hi,
Set to desired duration, then insert all desired images in the timeline/storyboard. However, you can only have one uniform duration.
You can only manually modify each image's duration if you want to.
