Ms Wolffie wrote:As soon as I start up PSP X7 I get this message
Image1.tif
I o not know how to get the autosave file back.
I have tried to re-activate it but that didn't work.
I did save some of the earlier works but, sadly, the one where I finally got it right was the one I lost when the screen froze.
Cheers
Ms Wolffie
I'm intrigued by your problem but still completely in the dark as to what you have done and what you have tried.
It sounds as if you were editing an image and your computer froze while you were saving. Perhaps you could describe what you were doing when you ran into the problem.
Are you able to use X7 now to edit other images? Do you have a version of the image you are trying to recover? If you do, select that and try from the menu Edit/Restore Original. In order to preserve originals Enable Auto-Preserve has to be checked in Preferences.
Originals are stored in a sub-directory of the directory from which you started named "Corel Auto-Preserve". Use Windows explorer to find the appropriate Auto-Preserve sub-directory and see what is there.
Could you provide a screenshot when the message you refer to comes up - at what stage of X7 opening.
