Anther question.
When I use my webcam (Logitech full HD 1080) to make stop motion film, the previous screen doesn't show in 16:9 format.
Is it normal? or should I be able to change some settings so the pictures are taken in 16:9 format?
No problem when I change resolution, but in the screen on the right, depending on the Capture resolution I see myself stretched up.
Thanks.
Alfons
Stop motion!!
alfons
- processor: i7 9700
- ram: 32GB
- Video Card: Gforce GTX1650
- sound_card: Sound Blaster Audigy FX
- Hard_Drive_Capacity: 1TBSSD+4GB
- Monitor/Display Make & Model: HP 24Uh
- Corel programs: VS X4-X5-X8-X10-2018-2020-2022
Re: Stop motion!!
Hi Alfons
What are the properties of the captured file, I suspect 1440 x 1080.
Without actually using the web cam I suspect VS is seeing that as 4:3.
Are you saying that the actual captured clips display on the timeline ok, as 16:9
That it is only the preview capture screen that is at fault. If so I don’t think you can change that and should simply ignore it.
alfons
- ram: 32GB
Re: Stop motion!!
It's Ok
On the previous screen it shows in format 4:3
Once I save it and I use it in the time line it dispalys in 16:9!!!
Many thanks
Alfons
Many thanks
Alfons
