PSP X7 - brushes changed
rpwalle
motherboard: Asus 580
processor: Intel i5 10400
ram: 32GB
Video Card: NVIDIA RTX3060
sound_card: none - integrated
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: ASUS 27inch 165Hz
Corel programs: PSP 2021 64 bit
Post by rpwalle »
since the last update (17.1.0.72x64) the brushes and effects have changed drastically. The push brush for example appears to be uncontrollable and leaves hard edges no matter what the setting. It used to be very easy to control. Has this problem been noticed by others? Suggestions for a fix?
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: PSP X7 - brushes changed
Post by trueblue »
Remember, choosing any tool you need to make adjustments to gain the right feeling and strokes you require. This means using the tool options palette and brush variance palette.
I asked collegues if they had noticed any difference and we concur there isn't any in the push brush. In fact, the push brush often behaves better than the smudge brush.
Are you using a mouse or pen/tablet? You get slightly different results using the mouse to a pen/tablet.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I can confirm rpwalle 's observation in X7 32 bit on XP machine.
There are two things called the push brush
1. In the group of brushes just below the paintbrush There is a Push and smudge and various other brushes (lighten /Darken) is the first
It is this brush that with hardness set at 0 still has hard sharp edgeds when pushing vertically or horizontally. Hardness 0 gives a rounded shape but with hard sides whil hardness 100 gives more a square shape.
This does not happen in X6.
2. The other Push brush is found in the Warp brushes under Warp Modes and this one has to be applied.
The result is similar but different but does respond to the Hardness value
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
hartpaul wrote:I can confirm rpwalle 's observation in X7 32 bit on XP machine.
Okay, now I see it. I was totally overlooking this brush and using the push brush that is part of the warp brush.
brucet
operating_system: Windows 8.1
Post by brucet »
Another 'glitch' I have struggled with is the Opacity setting. At 69% almost nothing happens. At 70% I get too much affect. I'm using a pen set on 'Normal'. 'Pressure' setting doesn't work for me.
I think it's time for Corel to do a full review of the Brush options.
regards
trueblue
Moderator
ram: 12GB
Post by trueblue »
I'm sorry, but I do not get the issues you refer. If I lower the opacity and hardness the brush is fine in both X7 and X6.
I would never use the warp push in painting.
~~~~Maureen~~~~
Creative-Designs
