Transparency with keyframes
queman
motherboard: ASRock Z77 Extreme4
processor: 3.40 gigahertz Intel Core i7-3770
ram: 8 GB
Video Card: Intel HD Graphics 4000
sound_card: Onboard Realtek High Definition Audio
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung SyncMaster 22 inch
Post by queman »
Hi All,
Using VSPX7 I'm trying do find a way to change the opacity of an overlay using key frames. I know it can be done using Custom Motion, but then other effects can't be applied. Under Pan and Zoom there is a transparency option at the bottom, but it is just a simple fade to a solid color. Is there any other way?
Thanks,
Queman
Re: Transparency with keyframes
Post by BrianCee »
Custom motion will also do pan and zoom at the same time - so why not use one function to all three together.
queman
ram: 8 GB
Post by queman »
Thanks Brian,
I have had another look at Custom Motion and it may work for me. I have found another option and that is the New Blue PIP filter. If you set beginning and end key frames to 100% you can then adjust the opacity as you wish using key frames.
Queman
