VS X8 does NOT have a customize option on output templates
DudeBoyz
Post by DudeBoyz »
As with seven, X8 does NOT have a customize option for exporting. This means when I select the WMV format and choose 1920x1080 at 30fps, I cannot go in and adjust any of the settings, say to 60fps and 10,000 bitrate.
Corel X5 HAS this feature. WHY do X7 and now X8 NOT have this feature?
They literally stripped this feature out of the program. It's incredibly frustrating.
How the hell am I supposed to output my Fraps recorded videos to the new 60fps YouTube format in this situation?
You SHOULD be allowed to select a format, copy the template from it's original to a newly named one and customize that template the way you want. If the template for WMV defaults to VBR, you should be able to set it to CBR. If the template for WMV defaults to 30fps, you should be able to adjust it to 60fps, for example.
Even my $19.99 copy of Magix Movie Edit Pro 15 lets you configure every setting you need when you choose to render a file. You don't even need to use profiles. The options are all right there, and it's as easy as you could possibly hope for. Why should Corel be so damn difficult?
Someone please enlighten me. How are we to get that feature back? X5 is still fully usable. But X7 and X8 are NOT, because of this missing ability. This is horrific.
See the Customize button in X5
There is no longer a Customize button in X7 or X8 - WHY???
Re: VS X8 does NOT have a customize option on output templat
It may be a licencing issue??????
Please contact Corel Support for an explanation as to why they removed the WMV customise templates option.
Instead of going that route, can you use the Add button -- and point it at a WMV clip with the Properties you want, to build a template? Sorry I can't help in a practical sense but I never use WMV format for anything so have nothing I can use to test this myself.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Profiles can be edited in notepad.
Or in profile editor as part of windows media encoder.
Extract the zip files into your
...\Corel VideoStudio Ultimate X#\Ulead.dat\WMV_Profiles\
folder where the wmv profiles are. Than load any prx and edit at will.
If it doesn't work than the full windows media encoder need to be installed
Be sure to back up your profiles.
Profiles editor.zip
(80.13 KiB) Downloaded 233 times
Panasonic X900m, VXF1
Hi Ken -- DudeBoyz
The add option from Share – WMV allows you to add a template/wmv Profile not a video file..
First you have to create that profile, earlier versions X5/X6 had a customise/advanced option that opened the WMV encoder, unfortunately Corel removed that option with the release of X7, and that’s the complaint, that we cannot access the wmv Encoder via Video Studio.
Ok Ken I forgot about Movie Manager
If you used Settings - Make Movie Profile Manager - WMV then the Add option would allow you to choose a video clip and indeed copy the properties. Just tried it and it worked ok.
DudeBoyz, if you choose one of your video clips using 60P.wmv then a share WMV template would be created allowing you to render to those properties.
You can of course choose a video file rendered using X5 which I assume you have access to.
Thanks Trevor.
DudeBoyz -- just remember when using the Add option, you have to leave the new template strictly alone after it is created. If you try to change even one property, it will revert to a default mpeg-2 template and you'd need to start all over again.
DudeBoyz
Post by DudeBoyz »
I thank you once again for all of your help. This board has always been a great source of assistance and I am grateful for your generosity and your time. I will look to work on each of the suggestions you have made.
I hope that some how, some way, Corel will address the situation and add the Customize option back to the program. There is so much that the updates can offer X5 users, if they would just restore this feature.
catplace
motherboard: Gigabyte GA-P67A-UD4-B3
processor: Core i7-2600K
Video Card: nVidia 570
sound_card: Soundblaster Fatality
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung B2440
Post by catplace »
For what it's worth, I too find the removal of this feature rather unfortunate. I've imported my old .prx files that were created using V11(!).
