Hi, I am a newbie and just registered,
I am running x7 pro on windows xp and have dowloaded software from a purchased DVD.
My problem is that somehow I have corrupted the files and cannot uninstall or indeed re install program from the DVD. Corel X7 pro is no longer listed in add/remove programs either. System restore will no longer work!!
Please can someone suggest a solution.
Regards
Lennie
videostudio x7 pro re-installation
carl365
- motherboard: Dell Inspiron
- processor: Intel i5-3330 3GHZ
- ram: 8 GB
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Acer
- Corel programs: Paintshop Pro X8
Re: videostudio x7 pro re-installation
Corel has a cleanup tool you can download. Better check with someone with more knowledge than me though.
You can try this clean-up tool - download - unzip - and run the resulting .exe file - then attempt to install from the disc again
lennie
- processor: Intel premium 4
- ram: 3GB
- Hard_Drive_Capacity: 250GB
- Monitor/Display Make & Model: philips 2401
Hallo Brian,
Many thanks for the Clean Up tool, It worked a treat. Everything now seems to be working correctly.
I have never before had such a good response from any of the forums I have joined in the past!
I thought I was going to have to do a System Recover with all that entails.
Many thanks once more
Lennie
Lennie
