PSP X6 problem
Old Finn
motherboard: MSI Z77A-G43
processor: Intel I5
ram: 8gb
Video Card: ATI Radeon HD 4300
sound_card: AMD High Definition Audio Device
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Eizo FS 2333
PSP X6 problem
Post by Old Finn »
When I use the adjusting tools in PSP X6, there has always been a link to reset the settings. Now that link has gone. I installed the program again, no help.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: PSP X6 problem
Post by MarkZ »
Old Finn:
Are you referring to Tools or the menu items in Adjust? Please give a specific example of the setting you want to reset. Can't help unless we know what you are having a problem with.
Mark
Old Finn
processor: Intel I5
ram: 8gb
Re: PSP X6 problem
Post by Old Finn »
Hey,
If I choose in Adjust for example Brightness/Contrast, seems that the area of that small program is smaller than before and the reset knob is left out. If I use "Smart photo fix", the area of the tool is restricted, I don´t see the end of the Histogram curve.
Old Finn
MarkZ
ram: 8 GB
Re: PSP X6 problem
Post by MarkZ »
Old Finn wrote:Hey,
Old Finn
My impression is that the input windows for the tools are about the same size as in the past. Smart Photo fix window can't be resized but in my case the area appears o.k. Regarding the Histogram curve, there was a time that the right side was cut off for those of us who use a Windows display of greater than 100% (I use 125% - Medium) but that was eventually fixed and in my version (16.2.0.20) I see the full display. Regarding reset, you can reset to default using settings, either in the settings box or the button on the far right.
It sounds as if there may be problems with your program. Try resetting by pressing the shift key while you open the program. Save your workspace first.
Mark
Old Finn
processor: Intel I5
ram: 8gb
Re: PSP X6 problem
Post by Old Finn »
Thanks Mark
Resetting helped
Old Finn
