64 bit PSP x7 ultimate installed ... how to install 32bit?
daveso
Post by daveso »
I installed the 64bit version of PSP X7 Ultimate .... but KPT will not work with it.
How do I now install the 32bit version?
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Re: 64 bit PSP x7 ultimate installed ... how to install 32bi
Post by Zantara »
PSP X7 has the option to install 32-bit, 64-bit or the combination of both.
The 64-bit runs smoothly on a 64-bit machine, but can't handle plugins.
If you install the combination, although working as seperate programs, you will still have problems with plugins in the 32-bit version.
Therefore, if you want to use plugins, install the single 32-bit version.
Then upgrade with servicepack 1 and use DEP-exclusion for X7.
Your plugins will run without problems.
You need to uninstall the 64-bit version first, which is a bit of a problem.
Corel recommends to use Windows Uninstall, but this leaves loads of files on both your C-drive and your registry.
With the 32-bit version it worked to click on the installer again, which uninstalls all of the files.
Then reinstall just the 32-bit.
