Corel Video Studio Has Stopped Working
TonyHam
processor: Intel Core i7-4770 CPU 3.40GHz
ram: 16 Gb
Hard_Drive_Capacity: 1 Tb
Monitor/Display Make & Model: HP S2031a
Post by TonyHam »
Hi, I know several people are having a similar problem but mostly when rendering. My problem comes at any time, perhaps after 5 or 10 minutes of editing, and I could be doing different things when it happens. Suddenly a message pops up saying "Corel VideoStudio has stopped working. A problem caused the program to stop working correctly. Windows will close the program etc etc."
I am running VS Pro X7 and I had downloaded SP1. However, reading some posts I decided to re-install from scratch and have not installed SP1 this time. I have also made sure I have the latest version of Quicktime.
My computer is running Windows 7 Home Premium 64-bit and has a 3.40GHz Intel Core i7-4770 CPU with 16Gb of RAM and 1 Tb of hard drive plus an external 1Tb hard drive I use for projects.
The files I am working with are MP4 video clips taken on a GoPro 3+.
Unfortunately I am a complete computer dinosaur so any help that is offered please keep it simple. Thank you in advance.
bobp
operating_system: Windows 8.1
motherboard: MSI MS-7519
processor: 9550 Core2-Quad core
ram: 8 GB
Video Card: Nvidia Gforce GTX-260
sound_card: On board HD audio Dolby 7.1
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Samsung SyncMaster
Re: Corel Video Studio Has Stopped Working
Post by bobp »
While you may be a "computer dinosaur", your computer is no slouch. But that doesn't mean it will take care of itself. The next time Video Studio closes, navigate to Control Panel/Administrative Tools/Event Viewer/expand Windows Logs on the left of the screen/select Application/scroll through the list at top center to see if there is an error for Video Studio at the time it crashed. If so it may tell you just what caused it. If not, look through the System section from the same tree.
You can practice by going there now, Windows stores this information for years sometimes.
TonyHam
ram: 16 Gb
Post by TonyHam »
Hi bobp, I really appreciate your help. I have looked at three errors from last night in the way you suggested and whilst most of the reports appear to be very similar the main difference seems to be in the line 'Faulting module name'. I hope you don't mind, as I have no idea what I am looking at, here is the last report in full with a a note at the end showing the 'Faulting module name' for the two previous reports.
Log Name: Application Source: Application Error Date: 08/02/2015 22:10:26
Event ID: 1000 Task Category: (100) Level: Error Keywords: Classic
User: N/A Computer: TonyCarolyn-Zoo
Description:
Faulting application name: vstudio.exe, version: 17.0.0.249, time stamp: 0x52bb3bf3
Faulting module name: H264VDec.dll, version: 5.4.0.4, time stamp: 0x5268ada6
Exception code: 0xc0000005 Fault offset: 0x00000000000fce4e
Faulting process id: 0xd10 Faulting application start time: 0x01d043e47dc84696
Faulting application path: C:\Program Files\Corel\Corel VideoStudio Pro X7\vstudio.exe
Faulting module path: C:\Program Files\Corel\Corel VideoStudio Pro X7\H264VDec.dll
Report Id: 484fecfc-afdf-11e4-97ea-ac220b4dc64f
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID>
<Level>2</Level> <Task>100</Task> <Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-02-08T22:10:26.000000000Z" />
<EventRecordID>29043</EventRecordID> <Channel>Application</Channel>
<Computer>TonyCarolyn-Zoo </Computer> <Security /> </System> <EventData>
<Data>vstudio.exe</Data> <Data>17.0.0.249</Data> <Data>52bb3bf3</Data> <Data>H264VDec.dll</Data> <Data>5.4.0.4</Data> <Data>5268ada6</Data> <Data>c0000005</Data> <Data>00000000000fce4e</Data> <Data>d10</Data> <Data>01d043e47dc84696</Data> <Data>C:\Program Files\Corel\Corel VideoStudio Pro X7\vstudio.exe</Data> <Data>C:\Program Files\Corel\Corel VideoStudio Pro X7\H264VDec.dll</Data> <Data>484fecfc-afdf-11e4-97ea-ac220b4dc64f</Data>
</EventData> </Event>
The two previous reports show the Faulting module as ntdll.dll and evr.dll both having the same faulting module path c:\windows\system32\ntdll.dll and evr.dll respectively, whereas the one above is a different path.
Once again any advice would be appreciated. Thank you.
bobp
ram: 8 GB
Post by bobp »
Thanks for posting the error logs. I'm glad you found them OK.
Uninstalling Video Studio does not remove everything. Somewhere in the Video Studio knowledge base is a routine for completely uninstalling VS. I would at the very least install the Sp1 update. If that doesn't work, then do the complete uninstall and reinstall.
TonyHam
ram: 16 Gb
Post by TonyHam »
I appreciate your advice and will try have a go at a complete re-install at the weekend.
With regards, TonyH.
TonyHam
ram: 16 Gb
Post by TonyHam »
Unfortunately my problems continue. Although I couldn't find details of how to carry out a complete un-install in the knowledgebase I did a complete un-install using a programme call "Special Uninstall". It seemed to find tens of hundreds of files all over the hard drive so I expect it did the job.
I then re-installed VS Pro7X plus the service pack and uploaded some video files that I had used in a successful film before plus some completely new clips. Within about ten simple edits I got the same error message saying that Corel VS has stopped working etc etc.
Faulting module name was ntdll.dll. I wondered if there might be a problem with Windows but my IT guy ran some diagnostics and found no problems.
Is it possible there is a problem with GoPro Mp4 file types?
A year or so ago I completed a nearly 3 hour video of my daughter's wedding taken on a Panasonic video camera which produces AVCHD (.MTS) files. No hitches at all. Now I try to work with the same files VS will not run them in the preview window (shows first two frames then stops) but will run them smoothly in the "single clip trim" window. Weird!
Any thoughts before I ditch VS altogether and switch to PowerDirector 13 instead would be gratefully received.
Well I use my GoPro Hero 3 quite a lot and have never had any problems editing. In fact I just finished a project using the Hero mp4 footage exclusively and it worked flawlessly.
That being said, some people have trouble when they use some of the Hero frame sizes which are not 'standard' such as 1920 x 1440 or 1280 x 968. VS spits the dummy with those. And as I said in a recent post about one of these, I guess I have just learned to avoid those formats and set my Hero to use more standard formats such as 1280 x 720p or 1920 x 1080...
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
It is strange Tony,
ntdll.dll is not part of VSX7, it's the OS error msg reporting dll, so why should it crash?
There is a small utility VSX7_Cleanup.zip run it after you uninstall VSX7
http://forum.corel.com/EN/download/file.php?id=6119
and than re install.
Panasonic X900m, VXF1
TonyHam
ram: 16 Gb
Post by TonyHam »
Thank you gentlemen, I have un-installed VS and run the clean-up programme. I will re-install at the weekend and see how things go. I will also check my GoPro settings although I will start editing with some trusted .MTS files from my video camera as that is what I will be using for my granddaughter's christening in a couple of weeks.
Once again, thank you. Cheers, Tony.
InsightPS
processor: Intel R Core TM i5
Hard_Drive_Capacity: 448GB
Post by InsightPS »
Hello folks!
So, I have been following this post because I have been having the same issue: Corel Video Studio stops working. What's amazing is that it stop working the second I try importing any videos into the program. It's a bit difficult to edit videos without the ability to import them. (I will paste the error report at the bottom)
Here are some other details:
I am working on a laptop -- This means NO CD DRIVE
However, I am working with a server (this is all through a business, so there's a lot of transferring through networks) that I have copied all the information from the software CD onto.
I have followed all of the instructions previously posted and am still having issues. Interesting tidbit though, the zip file, although pops up and claims to have cleaned the program off, shows the exact same thing if you look at it a second time.
Please help!! I don't want to waste another day of work battling this... It's damaging my ego.
As promised:
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2015-02-19T23:41:29.000000000Z
EventRecordID 159138
Channel Application
Computer Joe-Laptop
Security
- EventData
vstudio.exe
17.1.0.22
538721fe
igdumdim64.dll
10.18.10.3412
52e049a3
c0000005
0000000000340302
1640
01d04c9cc1cf6a5e
C:\WINDOWS\system32\igdumdim64.dll
d3227618-b890-11e4-bebd-bc8556a108d6
Faulting application name: vstudio.exe, version: 17.1.0.22, time stamp: 0x538721fe Faulting module name: igdumdim64.dll, version: 10.18.10.3412, time stamp: 0x52e049a3 Exception code: 0xc0000005 Fault offset: 0x0000000000340302 Faulting process id: 0x1640 Faulting application start time: 0x01d04c9cc1cf6a5e Faulting application path: C:\Program Files\Corel\Corel VideoStudio Pro X7\vstudio.exe Faulting module path: C:\WINDOWS\system32\igdumdim64.dll Report Id: d3227618-b890-11e4-bebd-bc8556a108d6 Faulting package full name: Faulting package-relative application ID:
jamesd1
Post by jamesd1 »
bobp wrote:While you may be a "computer dinosaur", your computer is no slouch. But that doesn't mean it will take care of itself. The next time Video Studio closes, navigate to Control Panel/Administrative Tools/Event Viewer/expand Windows Logs on the left of the screen/select Application/scroll through the list at top center to see if there is an error for Video Studio at the time it crashed. If so it may tell you just what caused it. If not, look through the System section from the same tree.
I'm having the same error and getting it every 5 minutes or so:
"Corel VideoStudio has stopped working"
Using latest update of quicktime.
Windows error log reports as copied below, But means nothing to me.
Thoughts?
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: vstudio.exe
P2: 17.1.0.22
P3: 538721fe
P4: mpegin.dll
P5: 17.0.0.249
P6: 529704b0
P7: c0000005
P8: 000000000004668a
P9:
P10:
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_vstudio.exe_f81a681425e5d4f61c3dd57bbba1aaaf79e7f2_ae005831_19d662ba
Analysis symbol:
Rechecking for solution: 0
Report Id: e18f3f3b-97de-41c7-9fcf-7df639e9fa21
Report Status: 100
Hashed bucket:
jamesd1
Post by jamesd1 »
And in follow up to my last post here is the file Windows log pointed me to.
Version=1
EventType=APPCRASH
EventTime=130878658098424059
ReportType=2
Consent=1
UploadTime=130878658562425733
ReportIdentifier=72463276-6565-11e5-9bea-d05099482d2e
IntegratorReportIdentifier=e18f3f3b-97de-41c7-9fcf-7df639e9fa21
NsAppName=vstudio.exe
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=vstudio.exe
Sig[1].Name=Application Version
Sig[1].Value=17.1.0.22
Sig[2].Name=Application Timestamp
Sig[2].Value=538721fe
Sig[3].Name=Fault Module Name
Sig[3].Value=mpegin.dll
Sig[4].Name=Fault Module Version
Sig[4].Value=17.0.0.249
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=529704b0
Sig[6].Name=Exception Code
Sig[6].Value=c0000005
Sig[7].Name=Exception Offset
Sig[7].Value=000000000004668a
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.10240.2.0.0.768.101
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=97d1
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=97d184fa009582a8373496d8e7a8dd02
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=b086
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=b086047f05473d6f2f1784302b66003a
UI[2]=C:\video\Corel VideoStudio Ultimate X7\vstudio.exe
UI[3]=Corel VideoStudio has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\video\Corel VideoStudio Ultimate X7\vstudio.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\system32\KERNEL32.DLL
LoadedModule[3]=C:\WINDOWS\system32\KERNELBASE.dll
LoadedModule[4]=C:\WINDOWS\system32\SHLWAPI.dll
LoadedModule[5]=C:\WINDOWS\system32\msvcrt.dll
LoadedModule[6]=C:\WINDOWS\system32\combase.dll
LoadedModule[7]=C:\WINDOWS\system32\RPCRT4.dll
LoadedModule[8]=C:\video\Corel VideoStudio Ultimate X7\UiaProvider.dll
LoadedModule[9]=C:\WINDOWS\system32\GDI32.dll
LoadedModule[10]=C:\WINDOWS\system32\USER32.dll
LoadedModule[11]=C:\WINDOWS\system32\OLEAUT32.dll
LoadedModule[12]=C:\WINDOWS\system32\IMM32.dll
LoadedModule[13]=C:\WINDOWS\system32\MSCTF.dll
LoadedModule[14]=C:\WINDOWS\SYSTEM32\mfc110.dll
LoadedModule[15]=C:\WINDOWS\system32\ADVAPI32.dll
LoadedModule[16]=C:\WINDOWS\SYSTEM32\MSVCR110.dll
LoadedModule[17]=C:\WINDOWS\system32\ole32.dll
LoadedModule[18]=C:\WINDOWS\system32\sechost.dll
LoadedModule[19]=C:\WINDOWS\system32\SHELL32.dll
LoadedModule[20]=C:\WINDOWS\system32\windows.storage.dll
LoadedModule[21]=C:\WINDOWS\SYSTEM32\MSACM32.dll
LoadedModule[22]=C:\WINDOWS\system32\kernel.appcore.dll
LoadedModule[23]=C:\WINDOWS\SYSTEM32\WINMM.dll
LoadedModule[24]=C:\WINDOWS\system32\shcore.dll
LoadedModule[25]=C:\WINDOWS\system32\powrprof.dll
LoadedModule[26]=C:\video\Corel VideoStudio Ultimate X7\u32Comm.dll
LoadedModule[27]=C:\WINDOWS\system32\profapi.dll
LoadedModule[28]=C:\WINDOWS\SYSTEM32\MSVFW32.dll
LoadedModule[29]=C:\WINDOWS\system32\COMDLG32.dll
LoadedModule[30]=C:\WINDOWS\SYSTEM32\d3d9.dll
LoadedModule[31]=C:\WINDOWS\SYSTEM32\SensApi.dll
LoadedModule[32]=C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10240.16384_none_89a94c179af51f83\gdiplus.dll
LoadedModule[33]=C:\video\Corel VideoStudio Ultimate X7\uAfxUnknown.dll
LoadedModule[34]=C:\video\Corel VideoStudio Ultimate X7\uTimeCode.dll
LoadedModule[35]=C:\WINDOWS\SYSTEM32\UxTheme.dll
LoadedModule[36]=C:\WINDOWS\SYSTEM32\WINMMBASE.dll
LoadedModule[37]=C:\WINDOWS\system32\cfgmgr32.dll
LoadedModule[38]=C:\WINDOWS\SYSTEM32\MPR.dll
LoadedModule[39]=C:\WINDOWS\SYSTEM32\MSVCP110.dll
LoadedModule[40]=C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10240.16384_none_f41f7b285750ef43\COMCTL32.dll
LoadedModule[41]=C:\WINDOWS\SYSTEM32\VCOMP110.DLL
LoadedModule[42]=C:\WINDOWS\SYSTEM32\dbghelp.dll
LoadedModule[43]=C:\WINDOWS\SYSTEM32\WININET.dll
LoadedModule[44]=C:\WINDOWS\SYSTEM32\dwmapi.dll
LoadedModule[45]=C:\WINDOWS\SYSTEM32\DEVOBJ.dll
LoadedModule[46]=C:\video\Corel VideoStudio Ultimate X7\ufctxeff.dll
LoadedModule[47]=C:\video\Corel VideoStudio Ultimate X7\MUIHelper.dll
LoadedModule[48]=C:\WINDOWS\system32\PSAPI.DLL
LoadedModule[49]=C:\video\Corel VideoStudio Ultimate X7\aft_plug\VST\NewBlue Corel Scrubbers Bundle64.pkc
LoadedModule[50]=C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9158_none_08e47e47a83d53d6\MSVCR90.dll
LoadedModule[51]=C:\WINDOWS\system32\MSIMG32.dll
LoadedModule[52]=C:\video\Corel VideoStudio Ultimate X7\en-US\AIKRC.dll
LoadedModule[53]=C:\video\Corel VideoStudio Ultimate X7\AIKRC2.DLL
LoadedModule[54]=C:\video\Corel VideoStudio Ultimate X7\uVeCfg.dll
LoadedModule[55]=C:\video\Corel VideoStudio Ultimate X7\uBaseObject.dll
LoadedModule[56]=C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll
LoadedModule[57]=C:\video\Corel VideoStudio Ultimate X7\UFCCOLOR.dll
LoadedModule[58]=C:\video\Corel VideoStudio Ultimate X7\HerDocdll.dll
LoadedModule[59]=C:\WINDOWS\system32\RICHED32.DLL
LoadedModule[60]=C:\WINDOWS\system32\RICHED20.dll
LoadedModule[61]=C:\WINDOWS\system32\USP10.dll
LoadedModule[62]=C:\WINDOWS\system32\msls31.dll
LoadedModule[63]=C:\video\Corel VideoStudio Ultimate X7\en-US\herrc.dll
LoadedModule[64]=C:\video\Corel VideoStudio Ultimate X7\UFCLIB.dll
LoadedModule[65]=C:\video\Corel VideoStudio Ultimate X7\FIO\u32ZLib.dll
LoadedModule[66]=C:\video\Corel VideoStudio Ultimate X7\PASMUtility.dll
LoadedModule[67]=C:\WINDOWS\system32\mfc110u.dll
LoadedModule[68]=C:\WINDOWS\system32\imagehlp.dll
LoadedModule[69]=C:\WINDOWS\system32\WS2_32.dll
LoadedModule[70]=C:\WINDOWS\system32\NSI.dll
LoadedModule[71]=C:\WINDOWS\SYSTEM32\bcrypt.dll
LoadedModule[72]=C:\WINDOWS\SYSTEM32\cryptsp.dll
LoadedModule[73]=C:\WINDOWS\system32\rsaenh.dll
LoadedModule[74]=C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
LoadedModule[75]=C:\WINDOWS\SYSTEM32\iertutil.dll
LoadedModule[76]=C:\video\Corel VideoStudio Ultimate X7\en-US\PCUDataIntl.dll
LoadedModule[77]=C:\video\Corel VideoStudio Ultimate X7\VTPCUNLR.dll
LoadedModule[78]=C:\WINDOWS\SYSTEM32\SspiCli.dll
LoadedModule[79]=C:\video\Corel VideoStudio Ultimate X7\PsiClient.dll
LoadedModule[80]=C:\WINDOWS\system32\WINSPOOL.DRV
LoadedModule[81]=C:\WINDOWS\system32\ondemandconnroutehelper.dll
LoadedModule[82]=C:\WINDOWS\system32\IPHLPAPI.DLL
LoadedModule[83]=C:\WINDOWS\system32\WINNSI.DLL
LoadedModule[84]=C:\WINDOWS\system32\winhttp.dll
LoadedModule[85]=C:\WINDOWS\system32\mswsock.dll
LoadedModule[86]=C:\WINDOWS\SYSTEM32\DNSAPI.dll
LoadedModule[87]=C:\WINDOWS\System32\msxml3.dll
LoadedModule[88]=C:\WINDOWS\system32\urlmon.dll
LoadedModule[89]=C:\Windows\System32\rasadhlp.dll
LoadedModule[90]=C:\WINDOWS\System32\fwpuclnt.dll
LoadedModule[91]=C:\WINDOWS\system32\VERSION.dll
LoadedModule[92]=C:\video\Corel VideoStudio Ultimate X7\u32Cfg.dll
LoadedModule[93]=C:\video\Corel VideoStudio Ultimate X7\en-US\u32Prod.dll
LoadedModule[94]=C:\video\Corel VideoStudio Ultimate X7\uDrawingTool.dll
LoadedModule[95]=C:\video\Corel VideoStudio Ultimate X7\u32File.dll
LoadedModule[96]=C:\video\Corel VideoStudio Ultimate X7\U32MISC.dll
LoadedModule[97]=C:\video\Corel VideoStudio Ultimate X7\uLauncher.dll
LoadedModule[98]=C:\video\Corel VideoStudio Ultimate X7\en-US\uLauncherRC.dll
LoadedModule[99]=C:\video\Corel VideoStudio Ultimate X7\uDVDUser.dll
LoadedModule[100]=C:\WINDOWS\system32\DCIMAN32.DLL
LoadedModule[101]=C:\video\Corel VideoStudio Ultimate X7\en-US\uDVDUserR.dll
LoadedModule[102]=C:\WINDOWS\SYSTEM32\PROPSYS.dll
LoadedModule[103]=C:\video\Corel VideoStudio Ultimate X7\uTextCfg.dll
LoadedModule[104]=C:\video\Corel VideoStudio Ultimate X7\libiomp5md.dll
LoadedModule[105]=C:\video\Corel VideoStudio Ultimate X7\U32VIDEO.dll
LoadedModule[106]=C:\video\Corel VideoStudio Ultimate X7\en-US\VioRC.dll
LoadedModule[107]=c:\video\corel videostudio ultimate x7\vio\Uvavi.vio
LoadedModule[108]=C:\WINDOWS\system32\AVIFIL32.dll
LoadedModule[109]=C:\WINDOWS\system32\QUARTZ.dll
LoadedModule[110]=C:\video\Corel VideoStudio Ultimate X7\libmmd.dll
LoadedModule[111]=C:\video\Corel VideoStudio Ultimate X7\uvBase.dll
LoadedModule[112]=C:\video\Corel VideoStudio Ultimate X7\uipp.dll
LoadedModule[113]=C:\WINDOWS\system32\DDRAW.dll
LoadedModule[114]=C:\WINDOWS\system32\imaadp32.acm
LoadedModule[115]=C:\Windows\System32\l3codeca.acm
LoadedModule[116]=C:\WINDOWS\system32\msadp32.acm
LoadedModule[117]=C:\WINDOWS\system32\msg711.acm
LoadedModule[118]=C:\WINDOWS\system32\msgsm32.acm
LoadedModule[119]=C:\video\CORELV~1\Dvacm.acm
LoadedModule[120]=C:\WINDOWS\system32\coml2.dll
LoadedModule[121]=C:\video\Corel VideoStudio Ultimate X7\uvUser.dll
LoadedModule[122]=C:\video\Corel VideoStudio Ultimate X7\en-US\UvUserRC.dll
LoadedModule[123]=C:\video\Corel VideoStudio Ultimate X7\ufctmtg.dll
LoadedModule[124]=C:\video\Corel VideoStudio Ultimate X7\ukMgr.dll
LoadedModule[125]=C:\video\Corel VideoStudio Ultimate X7\en-US\HerDocRC.dll
LoadedModule[126]=C:\video\Corel VideoStudio Ultimate X7\ulRender.dll
LoadedModule[127]=C:\video\Corel VideoStudio Ultimate X7\uRenderS.dll
LoadedModule[128]=C:\video\Corel VideoStudio Ultimate X7\UrenderA.dll
LoadedModule[129]=C:\video\Corel VideoStudio Ultimate X7\ulDARMgr.dll
LoadedModule[130]=C:\video\Corel VideoStudio Ultimate X7\uRenderGPU.dll
LoadedModule[131]=C:\video\Corel VideoStudio Ultimate X7\u32Base.dll
LoadedModule[132]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\VRMGR.dll
LoadedModule[133]=C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9158_none_08e47e47a83d53d6\MSVCP90.dll
LoadedModule[134]=C:\WINDOWS\system32\nvd3dumx.dll
LoadedModule[135]=C:\WINDOWS\system32\nvspcap64.dll
LoadedModule[136]=C:\WINDOWS\system32\SETUPAPI.dll
LoadedModule[137]=C:\WINDOWS\system32\nvapi64.dll
LoadedModule[138]=C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPI64.dll
LoadedModule[139]=C:\WINDOWS\system32\dxva2.dll
LoadedModule[140]=C:\WINDOWS\system32\d3dx9_36.dll
LoadedModule[141]=C:\video\Corel VideoStudio Ultimate X7\uRenderMT.dll
LoadedModule[142]=C:\video\Corel VideoStudio Ultimate X7\ulPPMgr.dll
LoadedModule[143]=C:\video\Corel VideoStudio Ultimate X7\ulPrev.dll
LoadedModule[144]=C:\video\Corel VideoStudio Ultimate X7\en-US\ulPrevRC.dll
LoadedModule[145]=C:\video\Corel VideoStudio Ultimate X7\upbPlug.dll
LoadedModule[146]=C:\video\Corel VideoStudio Ultimate X7\Vepb40.dll
LoadedModule[147]=C:\video\Corel VideoStudio Ultimate X7\uSurround.dll
LoadedModule[148]=C:\video\Corel VideoStudio Ultimate X7\U32mpb.dll
LoadedModule[149]=C:\video\Corel VideoStudio Ultimate X7\uvDV.dll
LoadedModule[150]=C:\video\Corel VideoStudio Ultimate X7\uvgrc.dll
LoadedModule[151]=C:\video\Corel VideoStudio Ultimate X7\U32mpbm.dll
LoadedModule[152]=C:\video\Corel VideoStudio Ultimate X7\sepa.dll
LoadedModule[153]=C:\video\Corel VideoStudio Ultimate X7\UPFMGR.dll
LoadedModule[154]=C:\video\Corel VideoStudio Ultimate X7\en-US\upfMgrRC.dll
LoadedModule[155]=C:\WINDOWS\system32\nvcuda.dll
LoadedModule[156]=C:\WINDOWS\system32\WINTRUST.dll
LoadedModule[157]=C:\WINDOWS\system32\MSASN1.dll
LoadedModule[158]=C:\WINDOWS\system32\CRYPT32.dll
LoadedModule[159]=C:\video\Corel VideoStudio Ultimate X7\uAMModule.dll
LoadedModule[160]=C:\video\Corel VideoStudio Ultimate X7\uvSmartProxyMgr.dll
LoadedModule[161]=C:\WINDOWS\system32\WindowsCodecs.dll
LoadedModule[162]=C:\WINDOWS\system32\dataexchange.dll
LoadedModule[163]=C:\WINDOWS\system32\d2d1.dll
LoadedModule[164]=C:\WINDOWS\system32\d3d11.dll
LoadedModule[165]=C:\WINDOWS\system32\dcomp.dll
LoadedModule[166]=C:\WINDOWS\system32\dxgi.dll
LoadedModule[167]=C:\WINDOWS\SYSTEM32\twinapi.appcore.dll
LoadedModule[168]=C:\WINDOWS\SYSTEM32\USERENV.dll
LoadedModule[169]=C:\video\Corel VideoStudio Ultimate X7\uGDIPlusTool.dll
LoadedModule[170]=C:\video\Corel VideoStudio Ultimate X7\UFCVECOMM.dll
LoadedModule[171]=C:\video\Corel VideoStudio Ultimate X7\u32Fido.dll
LoadedModule[172]=C:\WINDOWS\SYSTEM32\WINSTA.dll
LoadedModule[173]=c:\video\corel videostudio ultimate x7\vio\uvmpeg.vio
LoadedModule[174]=C:\video\Corel VideoStudio Ultimate X7\en-US\MPEG_VioRC.dll
LoadedModule[175]=C:\video\Corel VideoStudio Ultimate X7\uvHTMPEG2.dll
LoadedModule[176]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\ac3aout.dll
LoadedModule[177]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\pcmaout.dll
LoadedModule[178]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpgaout.dll
LoadedModule[179]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpgvout.dll
LoadedModule[180]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpgmux.dll
LoadedModule[181]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpg_dlg.dll
LoadedModule[182]=C:\WINDOWS\system32\oledlg.dll
LoadedModule[183]=C:\WINDOWS\system32\OLEACC.dll
LoadedModule[184]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpgcheck.dll
LoadedModule[185]=C:\video\Corel VideoStudio Ultimate X7\u32uscUI.dll
LoadedModule[186]=C:\video\Corel VideoStudio Ultimate X7\uvMPEGRO.dll
LoadedModule[187]=C:\WINDOWS\SYSTEM32\DWrite.dll
LoadedModule[188]=C:\video\Corel VideoStudio Ultimate X7\UFCUNDO.dll
LoadedModule[189]=C:\video\Corel VideoStudio Ultimate X7\ufcpnlbr.dll
LoadedModule[190]=C:\video\Corel VideoStudio Ultimate X7\uvCapModuleNotify.dll
LoadedModule[191]=C:\video\Corel VideoStudio Ultimate X7\u32Cvt.dll
LoadedModule[192]=C:\video\Corel VideoStudio Ultimate X7\uDVDUserEx40Lite.dll
LoadedModule[193]=C:\video\Corel VideoStudio Ultimate X7\UFCVEBUF.dll
LoadedModule[194]=c:\video\corel videostudio ultimate x7\vio\uvuis.vio
LoadedModule[195]=C:\video\Corel VideoStudio Ultimate X7\ulProjectIO.dll
LoadedModule[196]=C:\video\Corel VideoStudio Ultimate X7\eio\EIO.DLL
LoadedModule[197]=C:\video\Corel VideoStudio Ultimate X7\eio\AFT.EIO
LoadedModule[198]=C:\video\Corel VideoStudio Ultimate X7\eio\VST.EIO
LoadedModule[199]=C:\video\Corel VideoStudio Ultimate X7\VSTempTrans.dll
LoadedModule[200]=C:\video\Corel VideoStudio Ultimate X7\DrawImageMgr.dll
LoadedModule[201]=C:\video\Corel VideoStudio Ultimate X7\ConverDib.dll
LoadedModule[202]=C:\video\Corel VideoStudio Ultimate X7\Drawing\DrawDV.dra
LoadedModule[203]=C:\video\Corel VideoStudio Ultimate X7\en-US\DrawingRC.dll
LoadedModule[204]=C:\Windows\System32\devenum.dll
LoadedModule[205]=C:\WINDOWS\SYSTEM32\ntmarta.dll
LoadedModule[206]=C:\WINDOWS\system32\msdmo.dll
LoadedModule[207]=C:\video\Corel VideoStudio Ultimate X7\device\corelcamc.dll
LoadedModule[208]=C:\Windows\System32\PortableDeviceApi.dll
LoadedModule[209]=C:\video\Corel VideoStudio Ultimate X7\Drawing\DrawWinDevice.dra
LoadedModule[210]=C:\video\Corel VideoStudio Ultimate X7\DiGeneral.dll
LoadedModule[211]=C:\video\Corel VideoStudio Ultimate X7\ULSCRUB.dll
LoadedModule[212]=C:\video\Corel VideoStudio Ultimate X7\u32usp.dll
LoadedModule[213]=C:\video\Corel VideoStudio Ultimate X7\en-US\U32USPRC.dll
LoadedModule[214]=C:\video\Corel VideoStudio Ultimate X7\upppmgr.dll
LoadedModule[215]=C:\video\Corel VideoStudio Ultimate X7\PPP\DVRecording.ppp
LoadedModule[216]=C:\video\Corel VideoStudio Ultimate X7\en-US\PPPRC.dll
LoadedModule[217]=C:\video\Corel VideoStudio Ultimate X7\PPP\DvrMS.dll
LoadedModule[218]=C:\video\Corel VideoStudio Ultimate X7\PPP\DvrHDV.ppp
LoadedModule[219]=C:\video\Corel VideoStudio Ultimate X7\en-US\CU3PDVR_HDV_RC.dll
LoadedModule[220]=C:\video\Corel VideoStudio Ultimate X7\en-US\ufctxeffrc.dll
LoadedModule[221]=C:\video\Corel VideoStudio Ultimate X7\Veui32.dll
LoadedModule[222]=C:\video\Corel VideoStudio Ultimate X7\KeyFrameModule.dll
LoadedModule[223]=C:\video\Corel VideoStudio Ultimate X7\en-US\KEYFRAMEMODULERC.dll
LoadedModule[224]=C:\video\Corel VideoStudio Ultimate X7\UIShareTools.dll
LoadedModule[225]=C:\video\Corel VideoStudio Ultimate X7\en-US\veui32rc.dll
LoadedModule[226]=C:\video\Corel VideoStudio Ultimate X7\ulTitleMgr.dll
LoadedModule[227]=C:\video\Corel VideoStudio Ultimate X7\en-US\TitlePlugRC.dll
LoadedModule[228]=C:\video\Corel VideoStudio Ultimate X7\ulTitlePlug.dll
LoadedModule[229]=C:\video\Corel VideoStudio Ultimate X7\ufctxt.dll
LoadedModule[230]=C:\video\Corel VideoStudio Ultimate X7\ufcvren.dll
LoadedModule[231]=C:\video\Corel VideoStudio Ultimate X7\ufcpath.dll
LoadedModule[232]=C:\video\Corel VideoStudio Ultimate X7\ulTitleEng.dll
LoadedModule[233]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Curve.dll
LoadedModule[234]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Drop.dll
LoadedModule[235]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Fade.dll
LoadedModule[236]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Fly.dll
LoadedModule[237]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\PathAnim.dll
LoadedModule[238]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Popup.dll
LoadedModule[239]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Turn.dll
LoadedModule[240]=C:\video\Corel VideoStudio Ultimate X7\motion_plug\Zoom.dll
LoadedModule[241]=C:\video\Corel VideoStudio Ultimate X7\ulColorBar.dll
LoadedModule[242]=C:\video\Corel VideoStudio Ultimate X7\uHerObjs.dll
LoadedModule[243]=C:\video\Corel VideoStudio Ultimate X7\uTextTool.dll
LoadedModule[244]=C:\video\Corel VideoStudio Ultimate X7\uTextUser.dll
LoadedModule[245]=C:\video\Corel VideoStudio Ultimate X7\ulTitleData.dll
LoadedModule[246]=C:\video\Corel VideoStudio Ultimate X7\uVideoTool.dll
LoadedModule[247]=C:\video\Corel VideoStudio Ultimate X7\uvPointTrackingMgr.dll
LoadedModule[248]=c:\video\corel videostudio ultimate x7\vio\uvwav.vio
LoadedModule[249]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\iEncoder.dll
LoadedModule[250]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\DsVEncHP.dll
LoadedModule[251]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\MpgVEncHP.dll
LoadedModule[252]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\H264VEncHP.dll
LoadedModule[253]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mpegin.dll
LoadedModule[254]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\mcmpgdec.dll
LoadedModule[255]=C:\video\Corel VideoStudio Ultimate X7\uvSEPA.dll
LoadedModule[256]=C:\video\Corel VideoStudio Ultimate X7\PanZoomEngine.dll
LoadedModule[257]=C:\video\Corel VideoStudio Ultimate X7\FIO\u32Jpg.fio
LoadedModule[258]=C:\video\Corel VideoStudio Ultimate X7\en-US\FIO\FIORC.DLL
LoadedModule[259]=C:\video\Corel VideoStudio Ultimate X7\ulibjpg.dll
LoadedModule[260]=C:\video\Corel VideoStudio Ultimate X7\svml_dispmd.dll
LoadedModule[261]=C:\video\Corel VideoStudio Ultimate X7\uExifLib.dll
LoadedModule[262]=C:\video\Corel VideoStudio Ultimate X7\UfcAud.dll
LoadedModule[263]=C:\video\Corel VideoStudio Ultimate X7\en-US\ufcaudrc.dll
LoadedModule[264]=C:\video\Corel VideoStudio Ultimate X7\upl.dll
LoadedModule[265]=C:\video\Corel VideoStudio Ultimate X7\vft_plug\uvPipPath.vft
LoadedModule[266]=C:\video\Corel VideoStudio Ultimate X7\en-US\uvPiPpathRC.dll
LoadedModule[267]=C:\video\Corel VideoStudio Ultimate X7\Vft32.dll
LoadedModule[268]=C:\video\Corel VideoStudio Ultimate X7\en-US\vftrc.dll
LoadedModule[269]=C:\video\Corel VideoStudio Ultimate X7\MSPEEffectFunc.dll
LoadedModule[270]=C:\WINDOWS\SYSTEM32\edputil.dll
LoadedModule[271]=C:\WINDOWS\SYSTEM32\wintypes.dll
LoadedModule[272]=C:\WINDOWS\SYSTEM32\policymanager.dll
LoadedModule[273]=C:\WINDOWS\system32\msvcp110_win.dll
LoadedModule[274]=C:\WINDOWS\system32\XmlLite.dll
LoadedModule[275]=C:\video\Corel VideoStudio Ultimate X7\PexExif.dll
LoadedModule[276]=C:\video\Corel VideoStudio Ultimate X7\en-US\PEXEXIF_Res.dll
LoadedModule[277]=C:\video\Corel VideoStudio Ultimate X7\UCIMG.dll
LoadedModule[278]=C:\video\Corel VideoStudio Ultimate X7\UFCSTATU.dll
LoadedModule[279]=C:\video\Corel VideoStudio Ultimate X7\en-US\fio\uFioUtil.dll
LoadedModule[280]=C:\video\Corel VideoStudio Ultimate X7\uCodecUtils.dll
LoadedModule[281]=C:\WINDOWS\SYSTEM32\MMDevAPI.DLL
LoadedModule[282]=C:\WINDOWS\system32\wdmaud.drv
LoadedModule[283]=C:\WINDOWS\system32\AVRT.dll
LoadedModule[284]=C:\WINDOWS\system32\ksuser.dll
LoadedModule[285]=C:\WINDOWS\system32\AUDIOSES.DLL
LoadedModule[286]=C:\WINDOWS\system32\msacm32.drv
LoadedModule[287]=C:\WINDOWS\system32\midimap.dll
LoadedModule[288]=C:\video\Corel VideoStudio Ultimate X7\uplcpuinf.dll
LoadedModule[289]=C:\video\Corel VideoStudio Ultimate X7\Ulprntp.dll
LoadedModule[290]=C:\video\Corel VideoStudio Ultimate X7\en-US\ULPRNTPRC.dll
LoadedModule[291]=C:\video\Corel VideoStudio Ultimate X7\udevmgr.dll
LoadedModule[292]=C:\video\Corel VideoStudio Ultimate X7\CapMgr.dll
LoadedModule[293]=C:\video\Corel VideoStudio Ultimate X7\en-US\CapMgrRC.dll
LoadedModule[294]=C:\video\Corel VideoStudio Ultimate X7\XProfileAgent.dll
LoadedModule[295]=C:\video\Corel VideoStudio Ultimate X7\MpegSettings.dll
LoadedModule[296]=C:\video\Corel VideoStudio Ultimate X7\uvPlay.dll
LoadedModule[297]=C:\WINDOWS\system32\DSOUND.DLL
LoadedModule[298]=C:\video\Corel VideoStudio Ultimate X7\Vcvrt32.dll
LoadedModule[299]=C:\video\Corel VideoStudio Ultimate X7\cutime.dll
LoadedModule[300]=c:\video\corel videostudio ultimate x7\vio\uvMP4.vio
LoadedModule[301]=C:\video\Corel VideoStudio Ultimate X7\uvMP4Drv.dll
LoadedModule[302]=C:\video\Corel VideoStudio Ultimate X7\u32txEx.dll
LoadedModule[303]=C:\video\Corel VideoStudio Ultimate X7\ulmp4lib.dll
LoadedModule[304]=C:\video\Corel VideoStudio Ultimate X7\vft_plug\PanZoom.vft
LoadedModule[305]=C:\video\Corel VideoStudio Ultimate X7\en-US\vftatrc.dll
LoadedModule[306]=C:\video\Corel VideoStudio Ultimate X7\vftbase.dll
LoadedModule[307]=C:\video\Corel VideoStudio Ultimate X7\Dir12.dll
LoadedModule[308]=C:\video\Corel VideoStudio Ultimate X7\StopMotion.dll
LoadedModule[309]=C:\video\Corel VideoStudio Ultimate X7\StopMotionUser.dll
LoadedModule[310]=C:\video\Corel VideoStudio Ultimate X7\en-US\StopMotionRC.dll
LoadedModule[311]=C:\video\Corel VideoStudio Ultimate X7\U32BROWS.DLL
LoadedModule[312]=C:\video\Corel VideoStudio Ultimate X7\ufckey.dll
LoadedModule[313]=C:\video\Corel VideoStudio Ultimate X7\uOverlay.dll
LoadedModule[314]=C:\video\Corel VideoStudio Ultimate X7\en-US\UFCCOLORRC.dll
LoadedModule[315]=C:\video\Corel VideoStudio Ultimate X7\vft_plug\ColorAdjust.vft
LoadedModule[316]=C:\video\Corel VideoStudio Ultimate X7\Common Files\MPEG\MP2VDec.dll
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=Corel VideoStudio
AppPath=C:\video\Corel VideoStudio Ultimate X7\vstudio.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=433F7E1C96E79EE28EAD03986A2DE3C8
jamesd1
Post by jamesd1 »
I contacted Corel tech support about this error and they recommended upgrading. I finally resorted to that and moved from ver 7 to latest update of version 8, I think 8.5 or so actually. Anyway, it did not work. Today I was getting the error and a crash every 3 -4 minutes.
I'm again talking to support, but its very frustrating and I'm no completely hopeful they will solve it. I fear the program may just have critical problems with some hardware/software combinations. I have a moderately powerful system that more than meets specifications; running Windows 10.
canuck
Post by canuck »
jamesd1,
you have not included any information about your project which is where I think your problem lies. Just stating "I have the same problem" means nothing without some information about what you are doing, etc as well as info on your source material, etc.
Simply updating the program in most cases does not solve problems and salespersons are in often too quick to suggest that
BTW, you signature does not indicate anything "powerful" about your system.
jamesd1
Post by jamesd1 »
I upgraded to version 8 and still had the problem. Uninstalled and reinstalled to no avail. Finally, "Revo Uninstaller" which really cleans up old installations. Installed fresh after that, with all traces of early installs/version gone, and problem stopped.
I suspect that the problem is with the Corel installer because it gave no error but produced a flawed installed.
