After the Service Pack 1 I hoped, that the problem former reported was solved, but that is not the case .
When I tried to used CanoScan 9000F Mark II the PSPX7 freeze and must be stop via joblist (ctrl+alt+del).
There is no problems with the scanner. The way around is:
- Scan with Irfan View
Copy past the scan image to PSP
Save as
In one out of 10 cases the "save as" freeze with the filelist. If I then make joblist (ctrl+alt+del) the freezing stop and I don't need to close the PSP program. The file is saved correct.
Service pack 1 was not the solution for my problems.
There is a "Please make a better Service Pack 2" job for Corel.
