reinstallation of software and existing folders w/ media
antani1971
processor: i7 3630QM
Post by antani1971 »
Hi *,
I came across a problem in Screencap X6 ("an error occured on audio device") for which I found in another thread as possible solution a reinstall of VideoStudio X6
however I have a lot of materials loaded and categorized into VS from previous projects, that I would like to keep intact and available.
Therefore I'd like to know how can I 'export' those or if they will be available after uninstall/reinstall
Thanks anybody for helping here
Re: reinstallation of software and existing folders w/ media
Post by BrianCee »
If you go to "Settings >> Library Manager >> Export Library" you will be able to export your library - then after re-install you can use the Import Library option to bring them back - BUT - you do realise that what you see in VideoStudio is not your actual media files don't you - all those thumbnails are just links to the actual files which are somewhere on your hard drive.
Do you know exactly where those files are on your computer - if you have any in a folder at C:\Users\*user*\Documents\Corel VideoStudio Pro\17.0 then I would rename the folder to 17.0old just to be sure - but anywhere else on your computer they *should* be safe - never hurts to have a back-up though
antani1971
Thanks for helping
I found that in the uninstaller there is an option to explicitly remove all of the content. It was sufficient to leave the option unticked and the libraries were still there :-)
and now the screen capture works as well
thanks
G.
