Text mask
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Text mask
Post by terrypin »
Have I used the simplest method to make this 'text mask' please?
1. In PSP8 open new image, size say 640 x 300, black.
2. Set Text as Selection, colour to anything but black (I chose white) white, solid font (I chose Zurich Blk BT), size 108, Leading -350 (trial/error to get closeness).
3. Enter title and close text dialog, to get marquee.
4. Selection > Edit Selection, then used Deform to fill the window.
5. Selection > Edit Selection to return to normal mode.
6. Selection > Invert.
7. Copy (Ctrl+C) and paste new (Ctrl+V).
8. Save as PNG with transparency as alpha channel.
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Text mask
Post by LeviFiction »
Unsure
You could do this
1) Promote background Layer to regular Raster Layer
2) Produce Text as vector for editing purposes
3) Resize text to the size you want.
4) Selections -> From Vector Object to make a selection based on the text
5) HIde the text
6) Select the raster layer and Hit the Delete key to remove the area of the text
7) Save as PNG
OR
1) Create the text as vector with any color other than black
2) Resize the vector to match what you want with the Object tool
3) Export the image using the PNG optimizer and set the transparency as single color transparency selecting the color of the text that you made.
terrypin
ram: 32 GB
Re: Text mask
Post by terrypin »
Thanks. I like the sound of that second method, which I'll try shortly.
Edit: Now done so. Way better method than mine, thanks a lot.
