Edit out date on video frames
carl365
operating_system: Windows 8.1
motherboard: Dell Inspiron
processor: Intel i5-3330 3GHZ
ram: 8 GB
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Acer
Corel programs: Paintshop Pro X8
Post by carl365 »
On some of my videos I had the camera to show the date in the movies. Is there a way to edit out the date in VS?
Thanks!
Re: Edit out date on video frames
Post by BrianCee »
Not if you had it on when actually filming - it is embedded in the video and cannot be removed
best option is to put a "fuzzy" mask over it so that it at least blends in more with the image - the sort of thing often used to hide peoples faces on TV etc.
carl365
ram: 8 GB
Post by carl365 »
Thanks Brian, got it, fuzzy mask. I'll work on that today. Yes, unfortunately, at the time I thought having the date embedded would be good as a record.
Carl
carl365
ram: 8 GB
Post by carl365 »
Found another way that works fairly well. Since all the dates are on the bottom right of the frame, (luckily) by simply cropping the frame also works.
