I use Paint Shop Pro 7X, and I want to do the following –
a) Crop a photo, then
b) Bring the cropped photo back to full size, thereby losing resolution, and then
c) Fill in the resolution so that I have the same number of pixels as the original, but with the cropped shot.
Many thanks
upping resolution
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: upping resolution
Try: Crop as new image, then select resize and enter the same number of pixels for one of the dimensions (horizontal or vertical) as the original.
Mark
brucet
You could simply crop. Then Resize maintaining the dpi and inserting the desired dimensions in pixels.
regards
regards
DPainter
- motherboard: Gigabyte
- processor: Intel i7-7700 3.6GHz Quad core 8
- Video Card: nVidia GTX 1070
- Hard_Drive_Capacity: 2T HDD
- Monitor/Display Make & Model: 2 X SAMSUNG/s
- Corel programs: Paintshop Pro 2019 Ultimate.
I've never had success up sizing anything apart from Vector.
It blurs the image. The bigger the up size the worse it looks. Sharpen can help to a point but only once. "Sharpen more" isn't a good result I've found.
png, gif, psd, psp... Tried them all. None worked well enough.
