cannot install paintshop pro X7
lindenpunch
operating_system: Windows 8.1
motherboard: 2AE0 1.0
processor: 3.60 gigahertz AMD A8-5600K APU with Radeon HD Gra
ram: 7576 GB
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Samsung SA300/SA350
Post by lindenpunch »
Hello
I would be extremely grateful for some help with paint shop pro X7. I had recently installed a trial version of corel paint shop pro X7.I then uninstalled it and bought a boxed version. I am trying to install the boxed
version but keep getting the error message that it cannot be installed. please help, thanking you in anticipation.
Joelle
ram: 16 GB RAM
Re: cannot install paintshop pro X7
Post by Joelle »
I haven't been able to install X7 either.
Your message is more elaborate than mine, I was only told "your system has not been modified".
But when I look in the Registry, there is a lot of X7 debris there.
I tried using a System Restore point, which I set after removing X7 and before installing it again.
It failed.
Have you tried rolling back? to before you installed the X7 trial?
Joëlle
Joëlle
(PSPX9 )
DPainter
motherboard: Gigabyte
processor: Intel i7-7700 3.6GHz Quad core 8
Video Card: nVidia GTX 1070
Hard_Drive_Capacity: 2T HDD
Monitor/Display Make & Model: 2 X SAMSUNG/s
Corel programs: Paintshop Pro 2019 Ultimate.
Post by DPainter »
lindenpunch wrote:Hello
You could have just used the key (activation code) from the boxed version to license the D/L trial. Re-install the trial and it will prompt to buy. It'll ask you to buy or activate if you have got a A/C.
Not sure why it wont install over the trial though. It's the same program either way you get it.
DPainter
Post by DPainter »
Joelle wrote:I haven't been able to install X7 either.
It failed.
Joëlle
Is this a downloaded exe or a boxed version?
Could be a fault with the disc's?
If so try a downloaded install and use the disc A/C.
Joelle
ram: 16 GB RAM
Post by Joelle »
Mine is the download version, but that shouldn't make any difference.
I always make a back-up copy, once things are working properly, hah.. :-(
Joëlle
Joëlle
(PSPX9 )
lindenpunch
ram: 7576 GB
Video Card: onboard
sound_card: onboard
@joelle, I did a system restore point but it was to no avail, The error message I was having suddenly changed to the one you were having
lindenpunch
ram: 7576 GB
Video Card: onboard
sound_card: onboard
You are right, It did not dawn on me until you mentioned it,but by then I had already uninstalled it, now it won't let me install a trial version.
lindenpunch
ram: 7576 GB
Video Card: onboard
sound_card: onboard
@dpainter,You are right, It did not dawn on me until you mentioned it,but by then I had already uninstalled it, now it won't let me install a trial version.
DPainter
Post by DPainter »
lindenpunch wrote:@dpainter,You are right, It did not dawn on me until you mentioned it,but by then I had already uninstalled it, now it won't let me install a trial version.
There maybe some residue files left over from the first install. Like personal settings. Go to C/Programs Files/(for 64bit) or Programs Files (x86) for 32bit) Coral/Corel PaintShop Pro X7 (64-bit) is still there manually delete it. Look in both Program files wouldn't hurt.
Go to My Documents/Corel PaintShop Pro/0.7 in there. Delete that also. Not that this should be important to the loading on the program but it's not hard to delete so to take out any possible influence it may have.
Joelle
ram: 16 GB RAM
Post by Joelle »
That's easier said than done.
X7 entries are everywhere.
I went through all the Program Files, App data, registery entries (the lot) and deleted everything that said X7.
This should NOT have been necessary, the program should deal with this, not the user.
Short of reinstalling the OS, which at one stage I was considering, there isn't much more I can do.
In previous versions of PSP when you wanted to reinstall, the program would give you a choice of Install, repair or remove.
No such thing popped up this time, or I sure didn't get to see it.
X6 works very well and that's where I will stay until I have a lightbulb moment and solve the problem of why I can't install X7.
I have tried over 10 times now and am getting fed up with it.
Joëlle
Joëlle
(PSPX9 )
DPainter
Post by DPainter »
Joelle wrote:That's easier said than done.
Joëlle
Yeah I agree. It shouldn't be the case. Just thought it may help.
To be honest your better off with x6 anyway.
Joelle
ram: 16 GB RAM
Post by Joelle »
I am inclined to agree :-)
Had another rummage in the Registry, found more X7 entries in the HKEY_CLASSES_ROOT, did all the necessary, rebooted and nope, nothing, same message.
My stubborn side wants to keep trying, but I don't know where else to look.
In the meantime X6 is performing fast and well :-)
Joëlle
Joëlle
(PSPX9 )
rondo
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Post by rondo »
Best to use an uninstaller like Revo, free version works well. Gets all loose files that are scattered and removes all from registry.
Also, the Corel Clean Up Utility that they put out for X3 (same as Windows Install Cleanup Tool) will work on any software and remove what I mentioned above.
I've found Corel products usually need a complete uninstall and clean install to work properly. Only one I haven't had that problem with is Aftershot Pro 2, which I downloaded the trial, then bought a serial number.
Joelle
ram: 16 GB RAM
Post by Joelle »
Thanks Rondo :-)
Joëlle
Joëlle
(PSPX9 )
