X7 1080p 60fps
andygoth
operating_system: Windows 8.1
X7 1080p 60fps
Post by andygoth »
Hello, I'm looking for some help with output formats.
I currently render for YouTube in the following format.
MPEG-4 Files
24 bits, 1920 x 1080, 30 fps
Frame-based
H.264 High Profile Video: 15000 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
YouTube now supports 60fps uploads but I can find no way for X7 to render 60fps files in a youtube friendly format.
Is it possible?
Andy
Re: X7 1080p 60fps
Is your original video already in 60P format? If so, then make sure the box beside "Show Message when inserting first video clip" is ticked in Preferences > General. Then, when you start a new project and insert one of your clips, you should get a message asking if you want the Project Properties to match those of your clip. Click OK and go on with your editing. Then when you are finished, select Share > Same As Project Settings (or Same As First Clip) and you will get a new clip with identical properties to the original and suitable for upload to YouTube.
If your original video is not 60P, there would seem to me to be little point in trying to make it 60P as it will not improve the quality of the original.
