What is this operation called?
carl365
operating_system: Windows 8.1
motherboard: Dell Inspiron
processor: Intel i5-3330 3GHZ
ram: 8 GB
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Acer
Corel programs: Paintshop Pro X8
Post by carl365 »
Can't find how to do this. I just want to trim a segment of a video and move that segment to another part of the same video. Something like cut and paste.
Thanks!
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Re: What is this operation called?
Post by Terfyn »
Its called "Cut and Paste"! You can move the cut video back into the Library and then reuse it as required.
Post by BrianCee »
It is called 'editing'
use the scissors tool to make a cut each side of the segment you want to move - also make sure there is a cut at the position you want to insert it
using your mouse cursor click and hold on the segment and slide it along to the place you want it - release left mouse key
it is often easier if you drop down into an overlay track as you do that - you can see what your doing better
OR - as Terfyn has said - using the mouse left click and hold on the segment and slide it up into a library pane. delete the segment left in the video track
you can now slide that segment from the library panel into the video track (providing there is a cut/join there) as many times as you like just like any other clip in the library.
carl365
ram: 8 GB
Post by carl365 »
Thanks a lot guys! I wasn't aware you can drag from the timeline back into the library. This will come in especially handy with all the random short videos I have.
Carl
