Is there any possible way to do this?
I'd much appreciate it if it doesn't involve manually applying the effect each single slide, of course.
Thanks!
Adding the same transition effect to all slides
Re: Adding the same transition effect to all slides
yes you can do that in the timeline
with your slides in the timeline open the transitions library panel and select the transition you want to add
now at the very top of the library pane look for 4 little icons - - the first is a star with a plus sign - and the second is the one you want - click on it and the selected transition will be placed across every clip join
OR
if you are wanting to do it as you add the slides to the timeline the first go to "Settings >> Preferences" and when the preferences window opens click on the little 'edit' tab at the top of it.
now at the bottom of that page look to the options to automatically add transitions and to select which one - set what you want there and OK out of it
OR
