Corel AfterShot/AfterShot Pro Update 2.1.2.10
Dutchmm
operating_system: Linux
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
HDR with Sony A77ii
Post by Dutchmm »
This problem is reproducible on Linux Mint 17.1
nipponichi
System_Drive: N/A
Re: Corel AfterShot/AfterShot Pro Update 2.1.2.10
Post by nipponichi »
Alex Brazeau wrote:... we’ve been hard at work making improvements to the Fuji X-Trans profiles ...
The out-of-cam JPEGs are still better.
Noise reduction is very poor. Wavelet Denoise Plugin is currently the only usable one, acceptable at ISO1600, but not at ISO6400 - at least when comparing to the out-of-cam JPEGs.
Comparing processing of 8-mpixel Canon images with Bibble 5 and ASP1, ASP2 is very very slow on 16-mpixel Fuji images.
Reason might be the double amount of pixels and x-trans-pattern, nonetheless it is disappointing.
BR, Manuel
Kneops
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
I can't get Wavelet denoise working, so it's probably not compatible with 64bit OS. But I did get a quite good result with Perfectly Clear noise reduction.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Kneops wrote:I can't get Wavelet denoise working, so it's probably not compatible with 64bit OS. But I did get a quite good result with Perfectly Clear noise reduction.
Hmm ..
Are you using the 64bit version from this post http://forum.corel.com/EN/posting.php?m ... 6&p=297526
It appears to be working for me on 2.1.2.10 64bit Mint 17.1
R.
jknights
operating_system: Mac
motherboard: Apple
processor: Intel 3.08GHz Dual processor Quad Core
ram: 24GB
Video Card: ATI Radeon X1600
sound_card: Intel HDA
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: Apple Display
Post by jknights »
Running the latest ASP 2.1.2.10 and I have to say the results are much better than the previous betas and finals that I tested.
Well done to the teams at Corel.
We are making progress with Aftershot Pro again so that means that I have a useable product that I can use to make final output for my clients.
Some of the plugin developers have unfortunately not provided updated versions but I can work around that.
Still learning after all these years!
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Hmm ..
R.
No, I was aware of the existence of this post, so thank you for pointing it out to me. Now that I played with that plugin, I must say I get much better results using the Perfectly Clear Noise removal tool.
jknights
motherboard: Apple
ram: 24GB
Post by jknights »
Glad you have it working now.
I think it produces very good sharpening.
aspfan
System_Drive: N/A
processor: Intel Core i5
Video Card: Intel HD4000
Monitor/Display Make & Model: LG Flatron L222WT
Corel programs: AfterShot Pro 2
Post by aspfan »
New update works great on Ubuntu 14.04, thanks for adding Canon 7D MK II RAW!
Besides bug fixes what factor's help determine what improvements go into each revision?
I'm dreaming of some kick-*** noise reduction because I shoot at high ISO due to the low light, high shutter speed I need for sports and I miss how well Noise Ninja worked in ASP1.
Thanks ASP2 team!
fukapon
operating_system: Windows 8.1
Post by fukapon »
Hi. It's been a while.
A problem which occurs with 645Z PEF and Win 8.1 x64 is not fixed yet. I hope it'll be fixed in next release.
The problem report: http://forum.corel.com/EN/viewtopic.php ... 33#p298680
pureblack
System_Drive: N/A
Post by pureblack »
I have a problem with the raw files from Canon 7D MK II.
Imported, the raw file looks in violet tone with preset WB ( from the camera). If i change the WB, for example in Sunny or shade etc, the violet tone is preserved. But if i pick the WB from a white spot from the picture, the colours are fine.
How can I get rid of this mess?
Thank you!
