Right click menu missing
psplisa
motherboard: AMI PO1-A1
processor: PentiumRDual Core
ram: 4GB
Video Card: NVidia
sound_card: Realtek
Hard_Drive_Capacity: 700GB
Monitor/Display Make & Model: Dell IN1910N(Analog)
Post by psplisa »
Hi all,
I am using PSP8, a very old version from 2004. It still works great and I have it here at work on Windows 7. Recently, I noticed when I have the in-program browser open, when I right click on an image, the context menu is missing. All I get when I right click an image is a blank little box. I've tried the usual fixes aside from uninstalling/reinstalling. It was suggested by a fellow PSPer to try resetting to default by holding the Shift key and opening the desktop icon, but that didn't do anything either. I don't know if some Windows update caused the issue (the rest of my computer is fine), a .dll file went missing, or what.
If anyone has a suggestion, I'd appreciate it.
Thanks,
Lisa
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Right click menu missing
Post by Forriner »
It's been a while since I used PSP 8, but you could always customize menus, so you should bge able to reset. Have you tried that?
Start customize -right click just about anywhere and select Customize. Or menu View/Customize
Click on the Menu tab.
On the right side of the dialog box you see Context Menus. Select the context menu that you're missing from the drop down menu.
Click on the Reset button.
With any luck that should do it.
Good luck.
psplisa
ram: 4GB
Video Card: NVidia
sound_card: Realtek
Post by psplisa »
OMG!!! Thank you so much, it worked!!! I had to try several combinations and did several "resets", so I'm not sure which combo worked! :shock: :o But it worked. I've copied and pasted your response to my Notepad and saved it in case it ever happens again lol.
Thanks again, I appreciate your help!
-Lisa
Forriner
ram: 16 GB
Post by Forriner »
Great, glad it worked :)
