Program shows me that My video file is like Audio... why?
This is file properties: Why 0 frames???
I have another information about file :
Code: Select all
General
Count : 303
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : MPEG-4 (QuickTime): 23.1 MiB, 14s 633ms
Count of video streams : 1
Count of audio streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Video_Language_List : English
Audio_Format_List : PCM
Audio_Format_WithHint_List : PCM
Audio codecs : PCM
Audio_Language_List : English
Complete name : G:\DCIM\10050117\11450001.MOV
Folder name : G:\DCIM\10050117
File name : 11450001
File extension : MOV
Format : MPEG-4
Format : MPEG-4
Format/Extensions usually used : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
Commercial name : MPEG-4
Format profile : QuickTime
Internet media type : video/mp4
Codec ID : qt
Codec ID/Url : http://www.apple.com/quicktime/download/standalone.html
Codec : MPEG-4
Codec : MPEG-4
Codec/Extensions usually used : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
File size : 24253340
File size : 23.1 MiB
File size : 23 MiB
File size : 23 MiB
File size : 23.13 MiB
Duration : 14633
Duration : 14s 633ms
Duration : 00:00:14.633
Duration : 00:00:14:19
Duration : 00:00:14.633 (00:00:14:19)
Overall bit rate : 13259531
Overall bit rate : 13.3 Mbps
Frame rate : 30.000
Frame rate : 30.000 fps
Frame count : 439
Stream size : 1570684
Stream size : 1.50 MiB (6%)
Stream size : 1 MiB
Stream size : 1.5 MiB
Stream size : 1.498 MiB
Proportion of this stream : 0.06476
HeaderSize : 255344
DataSize : 23992984
FooterSize : 5012
IsStreamable : No
Title/More : CarDV-TURNKEY
Movie name/More : CarDV-TURNKEY
Encoded date : UTC 2015-01-17 11:45:54
Tagged date : UTC 2015-01-17 11:45:54
File creation date : UTC 2015-01-17 10:45:40.000
File creation date (local) : 2015-01-17 11:45:40.000
File last modification date : UTC 2015-01-17 10:45:54.000
File last modification date (local) : 2015-01-17 11:45:54.000
Origin : NVT-IM
Video
Count : 297
Kind of stream : Video
StreamOrder : 0
Inform : English, 11.9 Mbps, 1920*1080 (16:9), at 30.000 fps, AVC (High@L4.1) (CABAC / 1 Ref Frames)
Format : AVC
Format/Info : Advanced Video Codec
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : High@L4.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 1
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Internet media type : video/H264
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Codec : AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://developers.videolan.org/x264.html
Codec/CC : avc1
Codec profile : High@L4.1
Codec settings : CABAC / 1 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 1
Duration : 14633
Bit rate : 11893206
Bit rate : 11.9 Mbps
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Rotation : 0.000
Frame rate mode : CFR
Frame rate mode : Constant
Frame rate : 30.000
Frame count : 439
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.191
Stream size : 21754656
Stream size : 20.7 MiB (90%)
Stream size : 21 MiB
Stream size : 20.75 MiB
Proportion of this stream : 0.89698
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Audio
Count : 246
Kind of stream : Audio
StreamOrder : 1
Inform : English, 512 Kbps, 32.0 KHz, 16 bits, 1 channel, PCM (Little / Signed)
Format : PCM
Commercial name : PCM
Format settings : Little / Signed
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Codec : PCM
Codec : PCM
Codec/Family : PCM
Codec/Url : http://www.apple.com/quicktime/download/standalone.html
Codec/CC : sowt
Codec settings : Little / Signed
Codec settings, Endianness : Little
Codec settings, Sign : Signed
Duration : 14500
Duration : 14s 500ms
Duration : 00:00:14.500
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 512000
Bit rate : 512 Kbps
Channel(s) : 1
Channel(s) : 1 channel
Sampling rate : 32000
Sampling rate : 32.0 KHz
Samples count : 464000
Resolution : 16
Resolution : 16 bits
Bit depth : 16
Bit depth : 16 bits
Stream size : 928000
Stream size : 906 KiB (4%)
Stream size : 906.3 KiB
Proportion of this stream : 0.03826
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
