Not at all!!!baldrick777 wrote:[*]I used dispalGUI to calibrate my monitor with a Spyder4 loaned to me by a friend. I have two profiles, one (whose name aludes me) which was set as my system wide profile, the other was sRGB set as my user profile. How can I change the two around? I'm picking it's probably better to have the sRGB profile as system?
sRGB is a working space, not a screen profile. The screen profile contains a calibration part to bring the screen in a defined stated and a profile part that tells applications about the screen characteristics.
If you reset them, then all work was for naught. The goal is to bring the screen into a defined state.[*]When I was creating my profiles, dispalGUI requested I physically alter the RGB settings in my monitor so that they lined up with their calibrated model. Now that the monitor has been calibrated, can I reset my monitors RGB values back to default, or should I just leave them as they are?
After calibration you don't touch any monitor setting at all.
In the batch queue properties the output profile has to be set explicitly.[*]Did I understand you correctly when I thought you said that ASP2 automatically saves TIFFs as ProPhoto? If I got that wrong, can I get it to do so, and how? The 16bit part I'm ok with.
AS uses a ProPhoto variant internally, but the output is converted to whatever you set in the queue (or the preferences if you call Krita directly from AS).
Looks fine.[*]Should I have already configured Krita (settings/preferences/Color management/...
default color model for new images 'RGB (16-bit interger/channel)';
That should be you monitor profile that you generated with DispcalGUI, not your working space.Display/monitor profile 'ProPhoto RGB';
That is fine.Display/rendering intent 'perceptual' (default);
Leave them as they are.Should I change any other settings under Colour Management, or leave them as defaults?
Nothing essential here.Are there any other changes I should make in either program?
Not for the interaction...Any other tips or suggestions with regard to setting things up?!
If you find yourself copying specific settings often, check out Copy Sets in AfterShot. makes life faster.
cheers
afx
