How to delete a catalog
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
I made a mistake so I have a folder 2014 inside catalog 2015. I already removed the 2014 from the assets folder, but when I start ASP it still shows the folder.
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: How to delete a catalog
Remove all the files from the incorrect catalog and then right-click and select "remove empty folder".
Having said that, I have had a couple of instances where I have deleted all the files from within a folder, yet there are a few files that persist and cannot be deleted. I've removed the offending folder from the Corel ASP catalogs and from assets and still I get the folder and the files in ASP catalog. I've been in contact with the developers but no solution yet. Inability to work with the catalogs as one would with most folders is one of the weak points in ASP.
Mark
Kneops
- System_Drive: N/A
Thanks Mark, that worked.
That said, it would be much better and more logical if I could just remove a catalog folder, perhaps because I want to reïmport for some reason.
