Hi there!
I see in my catalogue than some of the thumbnails/previews (actually quite many), have a small white question mark in a red frame in the lower right corner. When I click the thumbnail, the real image is not found. This is probably, but I have not been able to confirm this, because the image could have been moved or renamed. Is there an easy way to clean up all these dummy thumbnails and remove them without having to delete them one by one? I have thousands of images imported.
/JonR.
House keeping routine for the catalogue
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: House keeping routine for the catalogue
The catalog function lacks the means to do this.
The only sensible way is to make sure you have XMPs generate a new catalog and then nuke the old one.
cheers
afx
cheers
afx
Thanks for quick response. As suspected, but though....
/JomR.
/JomR.
