I have issues with rendering.
Project looks perfect, MP4 when played on PC looks good too....but after posting the file on Youtube the file has audio and visual out of sync - a few seconds delay.
SOS!
Can you explain what you are doing, are you using the Upload to Web options then logging into YouTube.
That option does not give you the opportunity to play the video before uploading.
Do your project properties match your video files properties, some video types cannot do this.
Ok things to try….
1 / From Share – is the option Same as First Clip available, place a tick in the box to make the options available.
If same as First Clip is available and assuming that is your MPEG4 file, render to the hard drive.
You should also try deselecting Smart Render??
2 / Try Share – Mpeg4 – choose one of the profiles maybe 1280 x 720
Deselect Smart Render, then Start to render the project to your hard drive,
Play to check quality / audio sync’ before uploading to YT
