automatic detection
vasilis
sound_card: nvidia GTX 2060
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: ASUS G731GV
Corel programs: VS 2020
automatic detection
Post by vasilis »
with automatic detection can i add external subtitles?or is only for adding manually text?
Re: automatic detection
Sorry, but what 'automatic detection' are you talking about?
vasilis
Post by vasilis »
voice detection...i can use it with external subs or not? .i try it, i choose the right options and clik scan but when i clik in ''add new sub'' button apears a window with message : all settings will be lost.i want to add external sub with the best sync result.can i do it with automatic voice detection?
bobp
operating_system: Windows 8.1
motherboard: MSI MS-7519
processor: 9550 Core2-Quad core
ram: 8 GB
Video Card: Nvidia Gforce GTX-260
sound_card: On board HD audio Dolby 7.1
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Samsung SyncMaster
Post by bobp »
Are you talking about being able to speak titles into Video Studio rather than type them?
vasilis
Post by vasilis »
i did now this...should i speak in microphone and the voice detection recorded?i want to insert external(preset)srt subs with the best maching.can i do it with voice detection or with another way?until know i clik on ''insert new sub '' button in subtitle editor
No you do not speak into the mic'
Are you referring to STR files??
These can be added to the timeline from the “T” titles edit panel
Click the “T” symbol to open the titles library, select the Options (Far Right) to open that panel.
Choose Open Subtitle file, browse for your srt file.
All text boxes associated with that file will display in the timeline.
Using The SubTitle Editor
This is associated with specific audio / video clips, to open the editor we have to select a clip.
The length of that clip determines the total duration of the srt file and subsequently how many title/text boxes.
Once you have opened the Editor we could import a SRT file but will only display the titles upto the duration of the associated video clip.
Lets assume the SRT runs for 2 hrs 30 minutes associated with a movie.
The clip in the timeline has to be 2 hrs 30 minutes to use the Sub Title Editor.
You should use the same clip used to create the SRT.
vasilis
Post by vasilis »
so for betetr results which option is better?adding the srt file to timeline or add file with subtitle editor?
Ultimately you wish to match the text boxes to a video and that is best done in the timelines.
The SRT should match the video it was made for, all text boxes should be in position having the correct duration.
I don’t really know what problems you are having?
The SRT file is a TXT file……If you wish to manually change the timecodes then you can open the SRT using NotePad, all timecodes and text will be editable.
vasilis
Post by vasilis »
if the duration is wrong?
You are syncing the video’s voices with title clips, if the duration is wrong then you are best editing the clips in the edit timelines.
Are all title clips using the wrong durations, or is it just a few.
If you used Video Studio to create the srt file then the titles would be correct, but that means typing in all words again.
vasilis
Post by vasilis »
how sync video's voices with titles clip?what can do if all texts ''starts'' earlier than voice?
Either move all title clips along the timeline to the correct position, Shift Click first and last will select all.
Or
Move the video along the timeline, maybe add a colour clip at the beginning will allow you to set its duration/ length, nudging the video.
vasilis
Post by vasilis »
1)so i clik first and last text with shift ?
2)with this i will choose all texts?this is for sync?
3)sorry but i not understand yet if and how can i w ork with voice detection and external srt files
3 / You cannot work with voice detection and external srt files
vasilis
Post by vasilis »
ok thanks two more questions :
1)i hold shift and clik on first and last text for change duration?
2) if i drag subs to timeline how can choose font size?
