change subtitle duration
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
hello which by default subtitle duration and how can i c ahnge or make a better sync with VSX7?
Re: change subtitle duration
The duration of each sub-title depends on how much text is in it - I didn't think there is a default length for a sub-title - but once you have created a sub-title you can change it's duration as follows
In the subtitle editor click on the time of start or time of end of the sub-title - which ever number you click on will start flashing - at the same time two little arrows will appear to the right of the flashing number - click the up arrow to increase the number - when you have the right length set click OK at the bottom of the editor
vasilis
and i have to do for e ach text?one by one?
Yes
presumably each sub-title is a different length any-rate
vasilis
thanks.i aadd and another post about voice detection if you can help me.i want to add extrenal subs with the best maching..can i do it with voice detection or with another way?the text-ending earlier than speech....
Each sub title text length should be the same as the words being spoken, that’s how it works, so why do you need to change the duration?
Or are you trying to move the locations of the text boxes along the timeline.
vasilis
The text end earlier than speech...also how excactly work voice detection???i dont understant..i can use it with speech or with preset external subs???can you tell me?.no one tell me how it works...i try it but after scan i think if i insert external sub all settings will be gone(appears a windows with these informations)
SubTitle Editor
First are you creating your own SRT file or downloaded a SRT from the internet?
Place a video clip in the timeline ….
1 / How long is your video clip
2 / How many titles will you expect to make.
3 / select the subtitle editor starts a scan, this scans for audio changes within the video file, most of the audio changes will be voices, that’s the ones you are interested in.
4 / a list of text locations will populate the right panel, the durations of these should be correct
5 / for each of these you add the appropriate text. (Click Add a new subtitle to insert text)
6 / once complete I would suggest saving the SubTitle (Export Sub Title File)
7 / Pressing OK returns to the timeline, opening all completed text boxes.
Are the text boxes in line with the appropriate voice?
SubTitle Editor
vasilis
i downlaoded it.2 hours
vasilis
when choose voice detection and the scan finished i choose inmort subtitke file appears a window tolm all setting will be gone
Insert the srt file into the edit timelines, do not use the Subtitle editor
vasilis
ok i do it.and after that how insert the text in blanc boxes after scaning -voice detection?
vasilis
if i understand everything you told me:first insert srt files in timeline and aftert hat choose voice det?
Hi vasilis
We have two similar posts referring to your subtitle issues, to stop confusion I have locked this post
Please refer to this post
http://forum.corel.com/EN/viewtopic.php ... 38#p300110
