unsatisfying results with face recognition
waeller
operating_system: Windows 8.1
processor: Intel Core i5
Post by waeller »
Hi together.
I'm using PSP Pro X7 64bit and i have a very time consuming problem with the face recognition.
I have around 20.000 photos and my first try with face recogintion was to scan folders by year.
The result were many, many groups of faces even multiple groups for the same person.
Ok, i began to name the groups an hoped that the results would automatically refine, but they did not.
Next try was to delete all groups, rerun the recognition over one year and name the biggest groups hoping the recognition for the other "unknown" person would automatically refine.
But they did not.
Another try was to scan smaller folders with about 200 to 300 pictures hoping the face recognition will get better with each new folder.
But I have still a very inaccurate result. Even with pictures which look nearly the same.
Comparing to the picasa face recognition this is a very bad result :-(
Are there any hints, tips, workarounds or even a explanation of the recognition algorithm to get out of this "doom loop?"
kind regards,
waeller
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: unsatisfying results with face recognition
Post by MarkZ »
Waeller:
I think the lack of response since you posted indicates that very few people use face recognition. I believe this feature was introduced in version X5 or X6. I have used it only to test it and have had the same experience as you - it leaves much to be desired and Picasa is much better. It is useable for clear faces in relatively small numbers of images.
One other problem with this; let's say you were able to get face recognition to work on thousands of your images. You select a person, see a version you like and edit the image. If you want to store the new version in the same location as the original, you have no idea which folder it came from. In Manage mode the source of the image should be indicated.
Mark
AllBackJack
motherboard: PEGATRON CORPORATION TRUCKEE 1.04E01
processor: 3.07 gigahertz Intel Core i7 950
ram: 20GB
Video Card: ATI Radeon HD 4800 Series
sound_card: AMD High Definition Audio Devic
Hard_Drive_Capacity: 29TB
Monitor/Display Make & Model: DELL 2405FPW
Corel programs: Corel Pro 7, Pinnacle Studio 1
Post by AllBackJack »
I also find the facial recognition not as satisfying as with Picasa (and Picasa has basically gone away).
I was wondering if you had found any extra information that isn't on this posting thread.
It seems that in the thumbnails for the faces they are quite grainy as compared to Picasa. I was wondering if an explanation exists for the algorithm, or if any tweaks are available. Or even an off-line package.
