ASP 2.1.1.9 not starting
outsider787
operating_system: Linux
Hard_Drive_Capacity: 256GB
Post by outsider787 »
I have been a ASP user since the Bibble days, but never moved up to ASP2.
Today I decided to try out ASP2 and do some comparisons between ASP1 and ASP2 on my OpenSuSe 13.2 linux box.
ASP 2.1.1.9 installed file from the rpm file, but when I try to run it, it never starts.
It looks like it's a problem initializing the GPU?
I am running a R9 290 GPU with the latest (14.12) drivers from AMD.
ASP1 works just fine with OpenCL.
Anyone have any thoughts on how I can fix this?
0.4: AfterShot2 Pro New key used. 20
0.4: System locale: en_US
0.82: AfterShot2 Pro New key used. 20
0.108: AfterShot2 Pro New key used. 20
0.109: AfterShot vers.: 2.1.1.9
0.110: Built on: "Fri Nov 14 2014"
0.110: Language: en
0.110: App Path: /opt/AfterShot2(64-bit)/bin/AfterShotPro
0.110: System Home: /opt/AfterShot2(64-bit)/supportfiles
0.110: User Home: /home/outsider/.AfterShot
0.110: Prefs Home: /home/outsider/.config/Corel/AfterShot 2.conf
0.110: Platform: Linux
0.111: Issue: "Welcome to openSUSE 13.2 "Harlequin" - Kernel \r (\l)."
0.111: Kernel: "Linux version 3.16.7-7-desktop (geeko@buildhost) (gcc version 4.8.3 20140627 [gcc-4_8-branch revision 212064] (SUSE Linux) ) #1 SMP PREEMPT Wed Dec 17 18:00:44 UTC 2014 (762f27a)"
0.111: Build Mode: Release
0.111: Product Name: "AfterShot"
0.111: AfterShot2 Pro New key used. 20
0.111: Registered Version
0.112: AfterShot2 Pro New key used. 20
0.112: Initializing
0.113: Cpu Manager init: 6
0.113: **** Making CLManager
0.257: Got 1 platforms
0.257: OpenCL is disabled in low mem mode
0.257: platform 0x7fc78e62cfd0 "Advanced Micro Devices, Inc." OpenCL Version: "OpenCL 2.0 AMD-APP (1642.5)"
0.257: device: 0x3937260 "Hawaii"
0.408: Failed to create command queue for device 03937260
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: ASP 2.1.1.9 not starting
Post by afx »
Code: Select all
$ egrep -i opencl .config/Corel/AfterShot\ 2.conf
Preferences\OpenCL\Enabled=false
Preferences\OpenCL\CLUtilization=1
Preferences\OpenCL\PreferredPlatform=NVIDIA Corporation
Preferences\OpenCL\DeviceEnabled=NVS 4200M
Does the file already exist on your box? See if you can turn it off there...
cheers
afx
