I have recently upgraded from PSP X6 Ult. to X7 Ultimate, and the F1 function does not work: no help when I press it.
If I go to the Help menu, then it opens a browser and displays the online help trhough internet.
How to proceed in order to have the instalation files installed on the PC (and so available without an internet connnection ) ?
PSP X7 Help file not installed
nounours18200
- motherboard: Asus Z87-PRO
- processor: i7-4770K
- ram: 32GB
- Video Card: GTX-660
- Monitor/Display Make & Model: 24"
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: PSP X7 Help file not installed
Hmm? F1 works for me but I realize that doesn't help you much. To get a local copy of the Help File go to Help -> User Guide (PDF) and save the PDF file to your computer.
brucet
You can also get the help file by simply ignoring the 'online' popup when you are not connected. Ignore it and the built in help will open.
regards
https://www.flickr.com/photos/126753097@N02/
regards
nounours18200
- ram: 32GB
Easy to do , but this will probably not make the F1 working : will it ???To get a local copy of the Help File go to Help -> User Guide (PDF) and save the PDF file to your computer.
Kathy_9
I doubt it but it does get you a copy of the Help file. If it is that important to you to access the Help files via the F1 key, suggest you contact Corel as this is a User to User board.nounours18200 wrote:Easy to do , but this will probably not make the F1 working : will it ???To get a local copy of the Help File go to Help -> User Guide (PDF) and save the PDF file to your computer.
- hartpaul
- ram: 8 Gb
Are you always conected to the internet when you hit the F1 key as it seems to go to the site and load from there rather than using a local copy.
I have tested and F1 key works on an Windows XP and Windows 7 machine, but both are internet connected and I have not tried it offline.
