Hello all
And another one. Again it applies to a copy command, this time far more basic. Again I have the problem in AfterShot PRO and AfterShot 2. I am working with a German version, but this time I think it applies to all language versions, could someone please check in an English version and post if I am right - thanks.
If I am writing a text in to a IPCT field (as an example) and am marking the text, right mouse click then "Copy" and then go to another picture, click left mouse button in to a field (or same field) then right mouse button and "Insert" the text is pasted BUT when now changing picture and changing back the text is not there any more.
Doing the same with [ctrl][C] and then with [ctrl][V] all works. It also works if marked content is copied with mouse, so it seams that paste with mouse is the problem.
Please fix in new Version as soon as possible - thanks
Smart from Switzerland
Other Copy problem
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Other Copy problem
Works as it should. Linux, 64bit English.
cheers
afx
cheers
afx
Smart58
Yep, works when I switch AfterShot to English, but if I switch back to German then it does not work
So, it is a language problem - please take care of this soon - Thanks
Smart
Smart
