Hello all
Somehow I have a problem with Copy Sets. I am using AfterShot in German and the problem is in Aftershot Pro and in Aftershot 2 (Same).
When making a new or changing an existing "Copy Set" and then storing it the content of the selection is not recognized.
Example: Opening Preference, then Copy Sets -> new
Then defining a new criteria and giving it a name aswell as a dedicated key, saving it and finishing with "Apply" will save the Name of the Copy Set as well as the key which was dedicated but not the Aktion.
For example to copy the content of the title field in IPTC.
Reopening the stored copy Set will show all empty. Opening the XMP file with an external editor shows that the command is being stored (at least I could not see any mistake in the file). Somehow the file is not recognized correctly in AfterShot.
I also experimented by changing existing "Copy Set" files. If I erase all data and then enable new functions for copying these are also not stored.
Could be a bug due to German Version
Hope to get a bug fix on this matter real soon
Smart (Switzerland)
Copy Sets
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Copy Sets
Does it work when switching to English?
cheers
afx
cheers
afx
Smart58
Re: Copy Sets
No, does not change anything when switching to English, still same problem
Can someone else please check under Windows 8.1 - just to verify
Smart
Smart
