My concern, however, is that given what I see as absolutely identical settings, the compression levels for X7 have become MUCH worse on small pics. I have compression set at 30% in both programs and "embed ICC Profile" is on in both versions. Both are set for "standard encoding" and both have "save EXIF information" turned on. I can't find any other settings that even COULD be different, much less ARE different, yet I get wildly different results on small images.
Here are some stats from an arbitrary image:
Code: Select all
X3 X7
raw image from camera | 2648 | 2648 |
saved at 30% compression | 827 | 971 |
saved at 600 pixels wide / 30% | 22 | 37 |
saved at 200 pixels wide / 30% | 7 | 20 |
-------------------------------------------------Anyone have any idea what is going on here and whether there is a solution to this?
I can solve my issue by running a separate program to do a bulk reload/resave at 30% that I know gives about the same size as X3, but I don't see why I should have to do that. Why would X7 do such a poor job of compressing small images when X3 does a good job?
Thanks for any help.
Phinds
