Running the latest on Ubuntu 14.04 and noticed that deletion of an entry in the catalog does not actually remove the image from the file system. It used to work, and here is the documentation on the feature: "If you delete/remove a master version in Corel AfterShot Pro, the master file and all related versions are moved to the Recycle Bin."
I've tested this on a NAS and on a local folder catalog with identical results, the thumbnail entry is removed from the catalog, but not from the filesystem.
Anyone else with this problem ?
