ASP 2.0 with Canon 6D
ASP 2 is not rendering Canon 6D raw correctly. The raw appears a lots darker with grain. The jpeg show fine. I did not realize it till I opened the raw with Canon's DPP. In DPP the raw and jpeg are very close.
kumsa
- System_Drive: N/A
- motherboard: Dell Vostro V131
- processor: i5 2.4 Ghz
- ram: 8 G
- Video Card: Nvidia
- sound_card: Dell Laptop
- Hard_Drive_Capacity: Terabytes
- Monitor/Display Make & Model: Dell U2312HM, Acer
Re: ASP 2.0 with Canon 6D
Hm. I shoot RAW + JPG on my 6D (awesome camera) and I'm not seeing much difference (I'm assuming you have the latest release of ASP2). I wonder what JPG defaults you have set on the 6D
I am using whatever defaults ASP 2 has set for jpeg. The comparison is most obvious for indoor shots or low light. DPP renders raws with less noise and so they appear more natural. I tested the same raw image in both DPP and ASP 2. Maybe DPP being a Canon product renders Canon raw better than other software. Anyway, I will now use DPP more.
spoilerhead
- System_Drive: N/A
- Hard_Drive_Capacity: 13.5TB
check if you have "Highlight tone priority" enabled in the cameras settings. What this function essentially does is underexpose intentionally by 1 stop and then push it back when processing. DPP does this automagically, I guess ASP doesn't.
my ASP Plugins - donation button ( send beer!
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
Turning the "Highlight tone priority" off does bring about some parity in exposure. But, the noise levels in ASP 2 are much higher than DPP. I like the UI of ASP 2, but I am using DPP 4 now as it renders Canon RAWs much better. Maybe if Corel updates ASP with improved rendering in future I will start using it again.
