Adding Titles Question
ChrisTaylor
Post by ChrisTaylor »
Hi...
Im using DVD Workshop Express and what Im trying to do is edit DVDs that I record on my Panasonic set-top player.
The problem Im having is when I import the data from the DVD it splits the title into about 10 diffrent titles. Is there a way I can import the data into 1 single title or is there a way to merge the seperate titles into 1 single title??
Thanks,
Chris
GeorgeW
Post by GeorgeW »
Check your dvd recorder -- turn off auto-chaptering every "x" minutes (it might be set for every 10 minutes).
When DWS is importing your video, it breaks at each chapter mark that your dvd recorder is putting on the recorded video.
George
Devil
Post by Devil »
I have heard that most recorders will make a new VOB file every ~1 Gb because that is a limit of the DVD spec. It would seem unlikely that they make a new title (i.e., a new VIDEO_TS folder) for each VOB. If you take each VOB, converted into whatever, into WS2, then this will appear as a new title. If you stitch them together, then it will look at it as a single title.
So what you need is a way of stitching them together, before authoring. For this, you'll need an editor, such as VS9 or MSP7. However, there may a slight quality loss. Probably the best mitigation for this is to convert your VOBs to a low-loss format, such as DV Type 1 (you can find 0 or low-loss software for this on the Internet), do all your editing and make a new MPEG-2 file for authoring.
Number9
Post by Number9 »
Yep, DVDWS does this even if there are no chapter marks on your DVD - that makes no difference at all.
What you need is a programme like DVD Decrypter (now defunct sadly) which will demux your audio and video streams from the DVD, and give you one M2V and one AC3 file for the whole title.
I'm sure there are other programmes you can use for straight demuxing but I don't know any off the top of my head.
James
GeorgeW
Post by GeorgeW »
Ulead updated their Import from DVD feature in the latest VideoStudio 9 and DVD MovieFactory 4.0DC (to allow you to select one big title, or individual chapters) -- so I would think moving forward, new Ulead releases will add the same option...
George
