Can you save subtitles for multiple clips in one file?
huckrorick
Saving subtitles to an SRT file seems to have a lot of benefits. However, it seems like I would have to have a separate SRT file for each clip. That would be a lot of clips and becomes rather cumbersome. Is there any way to save all in a single file?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Can you save subtitles for multiple clips in one file?
SRT is just formatted text file with timecodes for translation sub's.
How do you want to use it for multi clips?
Panasonic X900m, VXF1
If you have a lot of subtitles on the timeline, using sub titles you do have a lot.
You can save all titles as a srt, (save Sub-Title file) will save all titles to one file.
That file can then be opened in the Sub-Title editor, first you have to select the video associated with the srt, or any long video, a video of a suitable length.
All the titles will show in the Sub-Title indicating the start and end times along with text.
huckrorick
Hi Trevor,
I'm not quite sure I understand.
For example, say I have 10 clips in a video. Each clip has dialog that I want to make subtitles for.
In order to open the subtitle editor I need to select 1 clip. I then add subtitles for that clip and save it to an SRT.
I then select another clip and open the subtitle editor and retrieve the same SRT.
I assume it will show the subtitles from the other clip, correct?
But they won’t be in the new clip that I have selected, correct?
Then, can I scan the new clip? And hypothetically say the second clip I am selecting is before the first clip. Where will the subtitles show? After the other clip? Or before, where logically they should be?
But I can add the new subtitles and save it and thereby have the subtitles for 2 clips in one SRT, correct?
If I then insert a clip between them, will the timing be all off?
I went to test this (rather than ask the question), but now the subtitle editor freezes my computer every time I use it. !@#*! Which raises some more difficult questions.
Huck
Huck
Hi Huck
there seems to be two posts referring to this problem, to stop confusion I have locked this post.
Please refer to:-
http://forum.corel.com/EN/viewtopic.php?f=1&t=55375
Please refer to:-
