when i go from manage to adjust to edit it starts closing down stuff...
that is a real pain.
why does psp x7 close my work
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: why does psp x7 close my work
Once you learn the logic of the program life get easier.rocket625 wrote:when i go from manage to adjust to edit it starts closing down stuff...
Use Manage to sort through thumbnails and find the image(s) you want to work with. You can use either Edit or Adjust to make changes to and image but not both. My preference by far is Edit, I stay away from Adjust (as I've written many times
It is possible to have a number of images open in Edit and to move between Manage and Edit without closing the files you are working on.
If you make a change in Adjust, the file is closed when you leave Adjust. You are prompted if you would like to save the changes. I think, and your comment indicates this, if you have files open in Edit, then open a file in Adjust, when you leave Adjust everything in Edit closes. Adjust is not very friendly.
Mark
MarkZ wrote:Once you learn the logic of the program life get easier.rocket625 wrote:when i go from manage to adjust to edit it starts closing down stuff...
Use Manage to sort through thumbnails and find the image(s) you want to work with. You can use either Edit or Adjust to make changes to and image but not both. My preference by far is Edit, I stay away from Adjust (as I've written many times)
Thanks I get it now. Seems like it would be good to get rid of manage and adjust make them into tool bars ( they maybe now ) and just have edit then your work would always be open sesame.
In File > Preferences > General Program Preferences, the last entry is 'Default Launch Workspace'. You can specify Edit there, and in future, when you open PSP, it will automatically always open in Edit mode.
