I'm probably gonna look stupid here, but I can't figure out how to get horizontal scrollbar for horizontal thumbnail filmstrip. Now vertical scrollbar here is very inconvenient. This changed within two last updates, can't tell which one since I did them both at once.
---Esa
Horizontal scrollbar
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: Horizontal scrollbar
Yes I have this problem too - I really don't like the vertical thumbnails!
The bug was introduced with 2.1.0.40 - see "http://forum.corel.com/EN/viewtopic.php?f=90&t=54856!"
afx opened a bug report (Oct 15, 2014) but unfortunately they did not fix it with ASP 2.1.1.9.
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
afx
- System_Drive: N/A
- Video Card: FirePro 4900
@esaahonen: Can you please post a screenshot? Just to make sure we understand.
@hannes_hab: I've tried to reproduce that issue and I think it might have been pilot error. I only get the regular strip by now.
cheers
afx
cheers
afx
esaahonen
- System_Drive: N/A
- motherboard: Asus P6T6 WS Revolution
- processor: Core i7
- Video Card: Nvidia GTX 650 Ti
- Hard_Drive_Capacity: 8TB
@afx: Here you go:
afx
- System_Drive: N/A
Can you pull down the thumbs area? When the cursor is on the border between the thumbs and the icons above the cursor should change shape to indicate where you can pull.
Also, try to toggle back and forth between horizontal and vertical thumbstrip (CTRL-L).
I initially reported an error about this but after running into it once, I never could reproduce it, so it seems some state change in the UI will get rid of it.
cheers
afx
cheers
afx
esaahonen
- System_Drive: N/A
I can resize it ok but that doesn't change the scrollbar. I've tried quite everything I can with it. Ctrl-L does what it's supposed to do, toggles the filmstrip orientation. No change in scrollbar though.
---Esa
---Esa
afx
- System_Drive: N/A
Silly me, I did not get your issue initially and confused it with something else.
Yes, I do have only a vertical scrollbar as well where I would expect a horizontal one.
cheers
afx
cheers
afx
