2.1.1.9 with D750 and D810 support
afx
- System_Drive: N/A
- Video Card: FirePro 4900
While the update notification still thinks it is extended cyber Monday, twitter told me there is an update out: 2.1.1.9
http://www.aftershotpro.com/en/support/updates/
cheers
afx
cheers
afx
Hobgoblin
- System_Drive: N/A
Re: 2.1.1.9 with D750 and D810 support
Ta!afx wrote:While the update notification still thinks it is extended cyber Monday, twitter told me there is an update out: 2.1.1.9
cheers
afx
I wonder what they will offer when they realise its Advent or even very nearly Christmas.
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Yes the Update notification mechanism seems to be stuck on the Black Friday/Cyber Monday feed!!!
Just downloading the new version to see if they have fixed the issues with the Fuji X-Trans demosaicing and CA!
Still learning after all these years!
Nikon D810 files does not show up on my Win 7 64bit computer in the latest asp version. I have the asp-pro 32bit version with this latest patch. I'm using the 32bit version in order to utilize some plug-ins. Anyone else with this problem? I check my Linux installation later tonight.
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
I'm curious to hear from you if it did. I'm planning on buying a Fuji myself and just tried out a few sample raf files on the internet and compared them with the available jpg versions. This ofcourse if difficult to compare because Fuji has so many preset jpg settings inside the camera. Anyway, I did my best to get the raf file to look like the jpg, but failed. My raf file is not as smooth as the Fuji jpg and has a bit more noise. The colors of the raf are better/more realistic than the fuji and I prefered the ASP version.jknights wrote:Yes the Update notification mechanism seems to be stuck on the Black Friday/Cyber Monday feed!!!
jknights
- ram: 24GB
X100S support seems to be better but still not great.
There is an improvement in general X-trans demosaicing but the Chromatic Aberration is still there for these images.
Slowly, slowly we will get there.
Alex Brazeau
Hi all:
As identified above, there's been a small hiccup in rolling out the ASP 2.1.1.9 automatic update... But we've got the team working to have it resolved as soon as possible. In the interim, if you would like to download and install the patch update, please download it from the Updates page of our website, which can be found here: http://www.aftershotpro.com/en/support/updates/
Thanks!
Thanks!
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
jknights wrote: There is an improvement in general X-trans demosaicing but the Chromatic Aberration is still there for these images.
Hello.
I gave a try to the new Aftershotpro 2 update on some high ISO files from my Nikon D810. I still need to experiment with some low ISO pictures, but so far the rendering makes the files totally unusable. So much that I still suspect that I miss something or do something wrong (and stupid). I'll (unfortunately) use the JPGs from the camera until the situation gets better. I managed to (sort of) recover one NEF file (ISO 3200) with the wavelet denoise plugin, but at ISO 5000 I could not recover anything.
Cheers
denis
Cheers
denis
fukapon
Unfortunately, 2.1.1.9 still has a problem same as 2.1.0.40 when it develops a raw PEF of Pentax 645Z. ASP draws black and white thick lines on the left and right.
I failed to attach a sample pic on this article (why? too large?), so I posted it to Flickr. https://www.flickr.com/photos/fukapon/15964765545/
I hope it will be fixed on next release.
FYI, on 2.1.0.40: http://forum.corel.com/EN/viewtopic.php ... 15#p296810
jknights
- ram: 24GB
Please can you post a link to the RAW file so I can test. Dropbox is good.fukapon wrote:Unfortunately, 2.1.1.9 still has a problem same as 2.1.0.40 when it develops a raw PEF of Pentax 645Z. ASP draws black and white thick lines on the left and right.
fukapon
Alright, it's the RAW file.jknights wrote:Please can you post a link to the RAW file so I can test. Dropbox is good.fukapon wrote:Unfortunately, 2.1.1.9 still has a problem same as 2.1.0.40 when it develops a raw PEF of Pentax 645Z. ASP draws black and white thick lines on the left and right.
https://www.dropbox.com/sh/al3ibh3dse15 ... 8.PEF?dl=0
jknights
- ram: 24GB
Just downloaded and processed the Pentax 645Z file on my MacPro with 2.1.19 (64bit).
No problems. No white/black lines at edges.
Seems to be a platform specific issue.
Trucks
- System_Drive: N/A
- motherboard: 64bit
- processor: quad
- ram: 3GB
- Video Card: Nvidia
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Eizo S2243 W
here on Xubuntu 14.04 i got the white line only on the right side. Already in the tracker.
Regards
Trucks
Regards
Trucks
fukapon
Oh, thanks. I didn't expect it's platform-dependent.jknights wrote:Just downloaded and processed the Pentax 645Z file on my MacPro with 2.1.19 (64bit).
I tried it with 2.1.1.9 64bit on Windows 8.1 x64.
