here is info for the video:
Code: Select all
General
Complete name : E:\....\FILE0001.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 94.0 MiB
Duration : 1mn 36s
Overall bit rate mode : Constant
Overall bit rate : 8 135 Kbps
Encoded date : UTC 2003-07-11 14:08:33
Tagged date : UTC 2003-07-11 14:08:33
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 36s
Bit rate mode : Constant
Bit rate : 8 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Original frame rate : 30.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.129
Stream size : 92.5 MiB (98%)
Language : English
Color range : Limited
mdhd_Duration : 96963
Audio
Format : ADPCM
Codec ID : 11
Codec ID/Hint : Intel
Duration : 1mn 35s
Source duration : 1mn 35s
Bit rate : 128 Kbps
Nominal bit rate : 136 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 16.0 KHz
Stream size : 1.46 MiB (2%)
Source stream size : 1.56 MiB (2%)
Language : English
Tagged date : UTC 2003-07-11 14:08:33If anyone has any tips I'd appreciate it.
