When I pause the Dropper Tool over a pixel in an image, a dialog box display numbers.
What do the various numbers mean?
In the example, the image is a 48 bit TIFF.
I see, R, G, B, O, and I guess that these are Red, Green and Blue, what is O?
Beside each, there is a colon followed by a number, 0, which would be 0 brightness? Next to that number, in brackets is (89), what is this number?
O has 255 and in brackets (65535) and at the bottom of the dialog it says, 100%.
I have been unable to find a reference somewhere that tells me what all these displayed numbers represent. I would appreciate it if someone could fill me in.
Thank you
What are the numbers associated with the Dropper Tool
tomkinsrichard
- motherboard: hp pavillion
- processor: amd
- ram: 4 gb
- Video Card: radeon
- sound_card: hp pavillion
- Hard_Drive_Capacity: 500
- Monitor/Display Make & Model: lcd
- Attachments
- DropperToolNumbers.png (4.8 KiB) Viewed 1502 times
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: What are the numbers associated with the Dropper Tool
O is for opacity.
The percentage I believe corresponds to the opacity value as well.
The numbers in parentheses gives the 16-bit value represented by the RGB values...I'm guessing. It only shows up when you use a bit value higher than 8.
